Author Topic: H pipe on dual exhaust.  (Read 56652 times)
Offline philo_beddoe
  • 77 C-10
« on: March 10, 2016, 05:11:36 pm »
I have full duals, should they be connected by that cross pipe or H pipe? If so, what are the benefits?
Offline Rattler12
  • Old Geezer
Re: H pipe on dual exhaust.
« Reply #1 on: March 10, 2016, 05:15:48 pm »
Evens out the pulses down each set of pipes, helps scavenging and doesn't sound like two four cylinder engines running down the road
83 C-10 shorty 454, 5spd, 3:73 posi
Offline rich weyand
« Reply #2 on: March 10, 2016, 05:34:10 pm »
The issue is that V-8s don't fire L-R-L-R-L-R-L-R, they fire L-R-R-L-R-L-L-R.  Those two pulses one right after the other result in cylinders 4 and 7 opening the exhaust valve into a higher pressure in the exhaust than the other cylinders see.  The X-pipe allows the extra pressure to go out the other side, where the H-pipe bleeds it off to the other side.  Almost the same, but people will tell you that X-pipes are better at high rpm for horsepower and H-pipes are better at low rpm for torque.
On a C truck you can do either, while on a K truck the X-pipe can be difficult to fit in there where the H-pipe is no big deal.  The H-pipe is probably better for a truck in any case.  The H-pipe need not be full exhaust diameter.  My exhaust is 2.25" and my H-pipe is 2".  Either goes as far forward as you can get it.
http://users.rcn.com/weyand/smalls/imag0315small.jpg
  • 77 C-10
« Reply #3 on: March 10, 2016, 07:19:34 pm »
Ok, good info. My brother told me it would benefit, i told him i'll check "my sources". Thanks, time to get the welder out.
Offline Captain Swampy
  • Wisconsin
« Reply #4 on: March 12, 2016, 11:23:02 am »
Hopefully around Easter we're going to have this muffler in Brooke's truck. It has the X in the muffler.
  • 77 C-10
« Reply #5 on: March 12, 2016, 05:08:50 pm »
Any pics of an H pipe application?
Offline Rattler12
  • Old Geezer
« Reply #6 on: March 12, 2016, 06:36:59 pm »
As for placement of the H pipe I heard somewhere that you should spray some rattle can paint down the side of the exhaust pipe, run the engine to temp and where it the paint stopped burning off is where to put the pipe.....???????/
  • 77 C-10
Offline SomeTexan
  • No such thing as too much hp
86 swb c10, LQ4/glide with 80mm turbo
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #10 on: March 13, 2016, 06:39:00 am »
Correct, closer to engine is better, some guys can fit it before tranny oil pan and the bellhousing-but that does make it hard for some to do tranny fluid changes
 1986 Chevy K30(under repair)
  • 77 C-10
« Reply #11 on: March 13, 2016, 08:23:04 am »
Ok, thats what i thought. Thanks
Offline Rattler12
  • Old Geezer
« Reply #12 on: March 13, 2016, 12:38:47 pm »
Made mine removable just for that reason..... easy trans removal if needed
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
« Reply #13 on: March 13, 2016, 01:07:10 pm »
Do you have a picture on how you did it by chance?
  • 77 C-10
« Reply #14 on: March 13, 2016, 04:23:08 pm »
I'd like to see a pic too...
