Author Topic: H pipe on dual exhaust.  (Read 56654 times)
Re: H pipe on dual exhaust.
« Reply #15 on: March 13, 2016, 08:09:56 pm »
An H pipe is ideal as it is not obtrusive for what it is. There's a pic of one on my 74 here before I welded it and had it coated to give you a visual. Think of it nothing more than a balancer for the exhaust. If you think you will see a difference with an X pipe over an H pipe then that's great but for your dd you won't. It's always good to believe in something I guess but having to drop your exhaust to access your trans pan will not afford your application any gains.
Offline HAULIN IT
« Reply #16 on: March 13, 2016, 09:09:38 pm »
Here's mine. I have not really cared for the sound of an X-pipe on most engines so I've stayed with the H...might make a couple extra HP at some point, but taking a nasty rumbling V8 & making it sound like a bumble bee isn't my thing. Lorne
Offline philo_beddoe
  • 77 C-10
« Reply #17 on: March 13, 2016, 09:11:33 pm »
Thats the exact set up i want, what i see in those pics.
« Last Edit: March 13, 2016, 09:14:00 pm by philo_beddoe »
Offline Rattler12
  • Old Geezer
« Reply #18 on: March 13, 2016, 10:35:59 pm »
Mine is like this except I made it in three pieces. Two short pieces welded to each exhaust pipe. then a center piece. I welded header flanges to the both exhaust pipe pieces and both ends of the center piece and bolted together with a header gasket in between each.
83 C-10 shorty 454, 5spd, 3:73 posi
Offline SomeTexan
  • No such thing as too much hp
« Reply #19 on: March 13, 2016, 11:41:16 pm »
http://www.mandrelbends.com/flanges-gaskets/exhaust-flanges/1-50-2-bolt-universal-exhaust-flange-1-4-mild-steel.html
4 of those, some bolts and gaskets you you have a crossover pipe that is removable. You could also use v-band flanges.
86 swb c10, LQ4/glide with 80mm turbo
  • 77 C-10
« Reply #20 on: March 23, 2016, 07:03:49 am »
Can you actually buy an H pipe or are they "made"?
Offline Captain Swampy
  • Wisconsin
« Reply #21 on: March 23, 2016, 10:23:21 am »
I think you can buy H pipe kits from Jegs and Summit.
Offline crx88ia
  • 77 K25
« Reply #22 on: March 24, 2016, 01:12:25 am »
Nice looking installs in this thread. Been thinking about doing it on mine. How much is fair for a shop to charge for one? I was quoted 600 for two mufflers and a H pipe.
Offline rich weyand
« Reply #23 on: March 24, 2016, 12:57:16 pm »
I paid $514 for complete replacement, 2.25", from the header flanges out the back, including two Flowmaster 40s, all new hangers, and a 2" H-pipe, installed.
  • 77 C-10
« Reply #24 on: March 24, 2016, 05:15:31 pm »
I got a $75 quote for just the H pipe install. And from a good muffler shop, private. Not one of those rip off hacks.
  • 77 C-10
« Reply #25 on: March 31, 2016, 10:51:53 am »
Went to have H pipe installed, the guy said i really would be wasting money on a simple daily driver. Plus there is really no place to put it, too far back does nothing. I did appreciate his honesty. He said when this system wears out he'll be glad to put in a  custom system with an H pipe done correctly. Also that cross pipe should aim down or back and not directly straight across, for the full mixture effect.
« Reply #26 on: March 31, 2016, 02:34:23 pm »
hmmm?
Offline blazer74
« Reply #27 on: March 31, 2016, 07:36:57 pm »
Devils advocate here. I call BS on either one H or X.
Other than look cool from on your back I seriously doubt your going see any noticeable difference.
Throw on a K&N filter with it and Wow!
New exhaust system sure why not add it.
Good flowing exhaust is just fine.
  • 77 C-10
« Reply #28 on: March 31, 2016, 10:52:42 pm »
Exactly blazer. In my application, no noticeable diff. This place has been doing exhaust systems since the 70's, i took my 70 chevelle there back in 85, did a super job. He could have easily made a quick $75, but told it like it is. New system, sure, add it in.
Offline Rattler12
  • Old Geezer
« Reply #29 on: April 01, 2016, 10:00:35 am »
You may not see a noticeable difference. You may not feel a noticeable difference. But you will hear a noticeable difference........ ;)
