Author Topic: Door Panel Attachment  (Read 7626 times)
Offline crawdad
« on: November 06, 2005, 06:16:00 pm »
The interior door panels on the 85 Silverado I just got are about to fall off.  Most of the screws and the "nuts" that pop into the door skin are missing.  Does anyone know where I can get some of these without having to buy the entire door panel?  Thanks.
Re: Door Panel Attachment
« Reply #1 on: November 07, 2005, 07:59:00 am »
Junkyard, or if you have the old ones any good auto parts store will have or be able to get them for you.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: November 07, 2005, 03:52:00 pm »
Like Blazin said, the good ole junkyard.  If you are near a big city, i am sure you would be pretty close to a large wrecking yard.  I love walking thru the one I have near me just to see what's out there.  I also take things off of the old vechicles just to see how they are attached.
You could also go to www. competitor.com  (1 -800   truck) Order a catalog that covers your truck.....they have everything.
SgtDel
383 stroker
91 4x4 3/4 ton GMC sub
Edited by: SgtDel at: 11/7/05 3:53 pm
Offline roundedline
« Reply #3 on: November 07, 2005, 03:04:00 pm »
The easiest place to find them is in the help section of a major auto store.  There are supposed to be 4 screws running across the bottom, one in the handle pocket and the weather stripping/lip at the top that actually hold it on though.  The plastic clips on the side only hold the sides.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline crawdad
« Reply #4 on: November 07, 2005, 07:06:00 pm »
I don't have the truck with me tonight as I've got a fellow rebuilding the carb for me.  I'll check it out tomorrow, but I could swear the 4 screws running across the bottom actually screwed into a plastic nut that you have to push into the 4 square holes I'm seeing along the bottom edge.  However, I don't remember and may be wrong, I'll check it out tomorrow when I get the truck back.  I've got  's catalog, and have ordered quite a lot from them already.  They don't have what I was describing though.  I'm having a time trying to get everything "tightened" up on this truck though.  The rattles are deafening when I hit bumps or go over tracks.  I'm just trying to eliminate them one at a time.  One day...
Offline roundedline
« Reply #5 on: November 07, 2005, 10:09:00 pm »
Maybe I missunderstood what you were asking.  There are plastic capture nuts that insert into the door.  Other than the HELP! section, I am not sure where to get it from.
Project Su
Jimmy 2WD Project
Offline crawdad
« Reply #6 on: November 07, 2005, 10:18:00 pm »
Yea, I probably wasn't too clear on what I was talking about.  So thats what you call them, capture nuts.  I'm hoping there is at least one left in the door so I can take it with me when I go hunting for some to show what I'm talking about.  I appreciate your help.
