Author Topic: Another header question?  (Read 9371 times)
Offline JoshsC10
« on: March 30, 2016, 11:49:36 am »
I ordered some hooker full length headers and the passenger side would not fit, I'm sending them back and looking at a set from headman they say their for my year but I am afraid I'm going to run into the same problem?? Any advice would be greatly appreciated. 83 c10 shortbed
Re: Another header question?
« Reply #1 on: March 30, 2016, 12:02:04 pm »
So why didn't they fit? Did you remove the starter?
Offline JoshsC10
« Reply #2 on: March 30, 2016, 12:16:58 pm »
Yes I removed the starter but I would of had to re route my exhaust around the crossmember
And I was looking for something that would of fit without any issues? I also have a bell tech 4/6 lowering kit and they were going to rub on the ground if I hit a bump. I have some no name long tube headers on it but there just really old and not in good shape.
« Reply #3 on: March 30, 2016, 12:45:24 pm »
small block or big block?
Offline JoshsC10
« Reply #4 on: March 30, 2016, 02:06:10 pm »
Small block
« Reply #5 on: March 30, 2016, 06:31:08 pm »
They have been making headers for these applications for so long I am surprised you can still buy a set with fitment issues for sbc applications.
Offline FlatBlack77
« Reply #6 on: March 30, 2016, 10:27:33 pm »
this thread might be helpful. i dont think they make headers that are a direct bolt in over the crossmember long tube design
http://67-72chevytrucks.com/vboard/showthread.php?t=701985
« Last Edit: April 01, 2016, 05:17:14 pm by FlatBlack77 »
Offline gunrac
« Reply #7 on: March 31, 2016, 06:35:11 am »
Back in the day everyone had custom headers. Hammer bangs up an down em'.......lol
Never Apologize..........as it shows signs of weakness
Offline bcstingray
« Reply #8 on: March 31, 2016, 04:02:33 pm »
I have Headman Headers on my build. They fit perfect. I had to move the gas lines and a brake line on the passenger side. I was able to put the passenger side on from above and the drivers side from below after removing 2 spark plugs. I have a double hump on my trans cross member (one hump on each side). My headers lined up with the humps pointing under the cross member.
Offline FlatBlack77
« Reply #9 on: March 31, 2016, 05:40:01 pm »
what part number do you have?
Offline bcstingray
« Reply #10 on: March 31, 2016, 06:48:49 pm »
I bought Headman part #69090. They ave the ball and socket type collector.  I have Sportsman II heads with angle plugs and this is what I had to have. If you don't have angle plugs, you might be able to use another part number. I bought mine from Summit Racing.
Contact Summit and ask them a question and they'll email back with the info on the headers for your build.
Offline JoshsC10
« Reply #11 on: April 08, 2016, 11:37:15 am »
I wound up welding my old headers where they broke and I'm going to have them coated. Thanks for all the help.
Offline Spoonbill
« Reply #12 on: August 24, 2017, 10:18:05 pm »
I have an 87 r10 305tbi 700r4. Long tube headers will hit every time. You need to get a set of headman mid-length headers and you won't have any problems. They have them in paint or ceramic coated.
