Author Topic: Changing speedo cable  (Read 6866 times)
Offline English
« on: April 01, 2016, 01:21:43 am »
Changing the speedo cable tomorrow, any tips? I hope there are no brackets halfway along or anything like that?
Offline impco lpg
Re: Changing speedo cable
« Reply #1 on: April 01, 2016, 04:32:16 am »
WHEN I CHANGED MINE, IT UNSCREWS AT THE TRANS. THERE IS A MOUNTING ON THE FRAME THAT THE CABLE GOES THROUGH.
AND THERE IS A SPRING CLIP THAT HOLDS SPEEDO  CABLE  TO DASH  CLOCKS
1983 cucv m1009  blazer 6.2 4x4
1991 1500 suburban 5.7 4x4 lpg
2003 dodge ram 5.7 4x4 lpg
1985 chevy c10 stepside  2wd 5.7ltr 350 lpg
Offline English
« Reply #2 on: April 03, 2016, 02:18:19 am »
Good news- the cable is fine, I don't need to change it after all
Bad news- it's the speedo itself that's knackered, it's seized up. D'oh!
Offline K20Detroit
« Reply #3 on: April 03, 2016, 02:22:55 am »
Now's your chance to install a fancy speedo. Be it a 100MPH speedo, speedo with tripometer, etc.
Myself? Having a diesel, I chose a speedo with tripometer.
Offline English
« Reply #4 on: April 05, 2016, 01:19:43 pm »
My speedo is 100mph already, does that make it a fancy one? If I was going to change it, I'd get a 60mph one, that would be plenty for me...
Offline warhorse
  • Lost Soul
« Reply #5 on: April 05, 2016, 05:01:07 pm »
North Hollywood Speedometer rebuilds the original units.  They'll also restore the appearance if you need it.  I just had mine mechanically restored for $180 plus shipping.   Works like new.  Just be sure to pack it to them carefully since the little needle snaps off if a heavy gust of wind hits it.  Plus, if you use the original speedo, you won't have the fuss of setting up the new one.
Tool shed!
Offline English
« Reply #6 on: April 09, 2016, 08:35:38 am »
Cleaned the speedo out with carb cleaner, then gave it a lube with WD40. Re-installed, it worked for twenty minutes then stopped again.
Looks like I'm going to have to take it apart and do it properly!
North Hollywood will be the last resort, what with me being in the UK, but thanks for the tip it's good to know such places exist
