Author Topic: Parking Brake Cable adjustment on Chevy K10 77 truck  (Read 6727 times)
Offline Fulltimechevy89
« on: April 06, 2016, 05:44:19 pm »
Hey all. I got a new parking brake cable and installed it on my Chevy K10 77 truck. There is just one equalizer adjustment and I am maxed out on it. The cable works, but its still a little loose, is there anywhere else I can adjust it to take up the slack? thank you
Re: Parking Brake Cable adjustment on Chevy K10 77 truck
« Reply #1 on: April 06, 2016, 05:52:03 pm »
Do not adjust the brake cable until you have adjusted the shoes correctly. If there is too much slack then you have the wrong cable(s) 77 is the older style. i believe they changed the design in 84 and then you have variations from weight class and wheel base.
« Reply #2 on: April 06, 2016, 06:05:12 pm »
Okay. I have drum brakes on the rear and is there an adjustment in there?
I don't have a tape on me now, but the one that came off was shorter. I got this one locally and they said its the shortest one they have.
« Reply #3 on: April 06, 2016, 06:33:05 pm »
Yes you need to clean, inspect and manually adjust the brake shoes. Install the correct cables and adjust and you will be good to go
« Reply #4 on: April 06, 2016, 06:38:51 pm »
Okay. Sounds good, I am going to exchange the cable and get them to match the old one. Thank you for the info!
