Author Topic: Turbo 350 no kickdown after changing carb  (Read 9041 times)
Offline l.neidlinger
« on: April 11, 2016, 07:36:02 am »
Hello all,
I have an 82 GMC c1500 with a 305/TH350 in it. After the third "professionally" rebuild quadrajet sucked a gasket I got a smoking good deal on a brand new Holley 4175. Probably a bit of overkill for a 305, but it runs very good and my pinging problems are gone now. However, now I have a problem with the trans.
The trans doesn't want to kickdown anymore, and it is short shifting. I checked the throttle movement, and it goes full throttle. I also checked the trans kickdown, at full throttle, I can't pull the cable out any further.
The only thing I can think of is that the vacuum modulator is receiving a different vacuum signal now causing the early shifts and no kickdown. Could an adjustable modulator fix this?
Re: Turbo 350 no kickdown after changing carb
« Reply #1 on: April 11, 2016, 08:04:22 am »
Thought I would add, the short shifting happens at WOT and hard acceleration only, otherwise, shift points are normal.
Offline LTZ C20
« Reply #2 on: April 11, 2016, 10:09:24 am »
Is the modulator hooked up to manifold or ported vacuum?
LTZ Cheyenne C20
« Reply #3 on: April 11, 2016, 10:14:08 am »
It's tapped directly into the manifold.
Offline mcintyrederek
  • Rookie
« Reply #4 on: April 11, 2016, 07:02:53 pm »
I would start my double checking the vacuum line.  If it's rubber/vinyl towards the modulator end, I've seen them "suck shut" and cause it do to strange things.
1986 C-10 Silverado 350 CI 260 HP, Edelbrock 1405, TH400, 2.73's - rescued from the junkyard - Farm Truck, daily driver!
« Reply #5 on: April 13, 2016, 06:56:54 pm »
Turns out there wasn't enough adjustment left and it wasn't pulling the kickdown cable far enough. I spaced it with a ziptie (heh) and it kicks down and winds out just as far as it use to.
Offline philo_beddoe
  • 77 C-10
« Reply #6 on: April 13, 2016, 09:02:36 pm »
Isn't there a range where the kickdown or "passing gear" as we used to call it, will work? In other words, if your going to fast it will not kick down? Mine kicks down up to about 30 mph i guess, wont kickdown at 40 mph.
« Reply #7 on: April 14, 2016, 11:26:17 am »
Yes. This is where I noticed the problem. With the old carb, it would do a 3-1 kickdown up to about 35 MPH, but I couldn't even get it to kickdown to first at all after I swapped carbs. I guess the clip for the kickdown on the Holley is a bit further back than the Quadrajet, so I had to space the cable with a zip tie for now until I can properly space it.
  • 77 C-10
« Reply #8 on: April 14, 2016, 03:10:15 pm »
Vile mentioned something about that on my truck, but i cant remember what he said. I'm not really sure how a kickdown works.  Where is this clip/cable?
« Reply #9 on: April 14, 2016, 06:41:45 pm »
You have a detent solenoid which is activated by a switch on the accelerator. The TH350 uses a detent cable for that purpose.
  • 77 C-10
« Reply #10 on: April 14, 2016, 09:20:58 pm »
Ok, thats that switch then just above the gas pedal.
Got it. Thanks.
« Last Edit: April 14, 2016, 09:23:58 pm by philo_beddoe »
« Reply #11 on: April 15, 2016, 03:59:50 pm »
Yes the switch is adjustable
  • 77 C-10
« Reply #12 on: April 15, 2016, 07:55:35 pm »
Ok,,,so what does adjusting it do? Do i need to adjust mine?
« Reply #13 on: April 16, 2016, 07:03:38 am »
Only if you want to change the downshift points
  • 77 C-10
« Reply #14 on: April 16, 2016, 07:34:45 pm »
I do, it needs to downshift at higher speeds.
