Author Topic: Window Regulator missing Crank?  (Read 7718 times)
Offline Spool
« on: April 17, 2016, 08:22:52 pm »
I have a 73' Chevy C20.
There is no crank assembly on my window regulator. Can I add the crank mechanism to it or do I need to replace the regulator all together?
I've recorded the inside of the door here : https://youtu.be/mlDLBZuMO_w
As of now the crank has been plugged on the door panel from the previous owner and I wish to make the window operable again with a crank rather than pushing it up or down myself.
Thanks guys.
Online bd
Re: Window Regulator missing Crank?
« Reply #1 on: April 17, 2016, 09:18:29 pm »
If you were freely moving the mechanism up and down in your video just by grabbing the glass, the regulator is shot.
Offline Spool
« Reply #2 on: April 17, 2016, 09:54:53 pm »
Makes sense.
I was shopping online for two new regulators and found a few at around $40 bucks a piece.
Would anybody be able to recommend a solid brand?
Offline Jason S
« Reply #3 on: April 18, 2016, 09:09:54 am »
Here's a bit of info you may want to look at prior to ordering any regulators:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=23598.0
Offline Spool
« Reply #4 on: April 18, 2016, 11:51:17 pm »
Thanks for the heads up Jason.
It appears that just because it's 3rd generation doesn't make it a perfect fit.
So if I narrow it down to specifically a 1973,
Would anybody be able to recommend a good vendor or site?
Online bd
« Reply #5 on: April 19, 2016, 12:18:53 am »
Visit the site store.  Email Captkaos ( webmaster@73-87chevytrucks.com ) with questions on particulars and availability.
Offline Spool
« Reply #6 on: April 23, 2016, 01:32:42 am »
Thank You BD!
Offline bcstingray
« Reply #7 on: May 19, 2016, 07:32:59 pm »
I just bought the drivers side regulator for my 73 C10 from RockAuto for $37.00 and that included shipping. received it today and was the correct one with the small rollers. I tried to use some off a76 and they had the large rollers.
Offline roundhouse
« Reply #8 on: May 20, 2016, 05:16:19 pm »
Yep 73 was a one year only small roller
Although it's not hard to swap rollers
You can also swap the splines shaft that stocks they the door panel
Which we had to do since the PO has stripped the splines and used JB Weld to hold the handles on
And we also wanted to use 82 door panels on the 73 doors
And the later years door panels are thicker requiring the longer spline shafts
« Last Edit: May 20, 2016, 05:20:52 pm by roundhouse »
« Reply #9 on: May 20, 2016, 07:43:13 pm »
Quote
What?  :D
Offline roundhouse
« Reply #10 on: May 21, 2016, 07:03:28 am »
Quote
What?  :D
Auto correct
You can swap the shaft with the splines on it that sticks thru the door panel
The one the window crank handle attaches to
