Author Topic: problem with my stereo {{{up date }}}  (Read 9319 times)
Offline alive 75
« on: April 20, 2016, 09:33:09 am »
outta no where this just started happening,, every time i put my foot on the brake pedal or turn my lights on my stereo goes off for about 5 seconds then comes back on, does anyone know what could cause this ?? thanks Danny
75 Chevy C-10 Scottsdale trim.
350 factory 4 bbl carb w/AC
after-market pioneer stereo
« Last Edit: April 24, 2016, 12:04:15 pm by alive 75 »
Re: problem with my stereo
« Reply #1 on: April 20, 2016, 10:58:40 am »
maybe a ground issue? not sure but grounds can do weird things
Offline rwilliamz
« Reply #2 on: April 20, 2016, 02:20:48 pm »
My 83 c-10 is doing the same thing. Sometimes when I push in the clutch also.  I changed out the radio and ran a new ground to the dash framework just in case I had a broken ground wire but it's still happening!?!?!?
« Reply #3 on: April 20, 2016, 02:33:29 pm »
might be a bad connection at the bulkhead.
Offline K20Detroit
« Reply #4 on: April 20, 2016, 03:10:34 pm »
Mine did the brake pedal thing for a bit, it ended up being a loose connection where the aftermarket wiring was installed.
It wasn't until I actually took apart the wiring and redid them that I could find the one that was doing it.
Is the entire radio shutting off? On mine, the power wire on the trucks radio plug frayed and had snapped off. I fixed that before having the other wiring issue.
« Reply #5 on: April 20, 2016, 03:51:01 pm »
Gently jiggle the harness while the radio is playing to see if you can simulate the symptoms.  Recheck splices and wire connections to the radio and reconcile them against the radio's wiring diagram and instructions.  In addition, the cab maybe grounding through the brake and clutch linkages instead of grounding via the cab-to-engine jumper cable, resulting in intermittent grounding of the cab.  So...
Check the radio ground connection to the cab AND check the ground jumper connections between the cab and back of the right cylinder head.  Make sure that ground connections attach to shiny bare metal and that they are coated with antioxidant to inhibit corrosion.
Similarly, check the ground jumper connections between the cab and back of the right cylinder head.  Make sure that ground connections attach to shiny bare metal and that they are coated with antioxidant to inhibit corrosion.
Offline Fulltimechevy89
« Reply #6 on: April 20, 2016, 06:51:21 pm »
I have a pioneer stereo in my 77 350, I had a problem with it shorting whenever I'd go over a large bump. Could be a connection problem with yours, sometimes all the wires are just cheaply taped together on these.
Offline OldGray
  • Ne'er-do-well
« Reply #7 on: April 21, 2016, 03:38:58 pm »
Maybe the brake pedal is moving a wire that is not well placed?
1979 Chevrolet Bonanza / 305 / LWB
Offline alive 75
Re: problem with my stereo {{{up date }}}
« Reply #8 on: April 24, 2016, 12:07:58 pm »
well what i did was ran a ground wire from the negative side of the battery to the fender and the problem has been solved,,,
although now everything electrical works fine except the blower fan switch is not working  and it was working before i ran the ground wire,, now what can this be ?????
« Reply #9 on: April 24, 2016, 12:46:04 pm »
well what i did was ran a ground wire from the negative side of the battery to the fender and the problem has ...the blower fan switch is not working and it was working before i ran the ground wire,, now what can this be ?????
Not working as in the blower motor doesn't work?  Check the fuses and make sure the blower motor is properly grounded to the cab, then...
...check the ground jumper connections between the cab and back of the right cylinder head.  Make sure that ground connections attach to shiny bare metal and that they are coated with antioxidant to inhibit corrosion.
Or, not working as in there is only one fan speed?
Offline alive 75
« Reply #10 on: April 26, 2016, 06:53:29 pm »
thanks for the reply......everything works perfect until i turn on my headlights,
« Reply #11 on: April 26, 2016, 08:16:55 pm »
And then what happens?  If you want help you need to be a little clearer.
