Author Topic: Charcoal Canister  (Read 6587 times)
Offline bcstingray
Charcoal Canister
« on: April 24, 2016, 08:35:42 am »
Should I keep the charcoal canister in my 73 build?
Offline hatzie
Re: Charcoal Canister
« Reply #1 on: April 24, 2016, 08:56:57 am »
No performance hit and it actually keeps the garage from smelling like raw fuel.
If you don't like the visual presentation stuff it under one of the battery trays and re-route the hoses or find some other place to hide it.
« Last Edit: April 24, 2016, 08:58:43 am by hatzie »
« Reply #2 on: April 28, 2016, 06:08:00 pm »
if its not needed for inspection then remove it but i would set it aside if you have the room so just in case if you need it you can find it
Offline big_al273
« Reply #3 on: April 28, 2016, 08:43:39 pm »
unless you want to smell gas around your truck all the time keep it, it will make it a lot easier to tell if you have a fuel leak or not without the constant smell of gas
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
Offline philo_beddoe
  • 77 C-10
« Reply #4 on: April 30, 2016, 08:21:51 am »
However it came off the assembly line.
Offline hatzie
« Reply #5 on: April 30, 2016, 10:24:24 am »
There are three connections to the evap can.
Tank vapor vents.
Vapor purge teed into PCV hose.
Purge control vacuum teed into distributor vacuum advance hose.
There are lots of different shaped evap cans with the three basic connections that could be mounted under the cab to hide them.
Most carbs used on these trucks have float bowls vented inside the air filter so there are no bowl vent hookups.
Sent from my SM-P605V using Tapatalk
« Last Edit: May 01, 2016, 08:28:36 am by hatzie »
  • 77 C-10
« Reply #6 on: April 30, 2016, 09:29:47 pm »
Mine has vent from carb teed into air cleaner assy.  And the other line off of the canister goes to the fuel tank.
Offline hatzie
« Reply #7 on: May 01, 2016, 08:31:30 am »
Rochester 2G and Quadrajet carbs vent the bowl straight up next to the choke plate.  I fill the bowl through the vent to prime em after sitting.  It's some of the 1G carbs on the I6 where you get the external vent.
« Last Edit: May 01, 2016, 08:33:15 am by hatzie »
Offline bcstingray
« Reply #8 on: May 01, 2016, 08:45:36 am »
I don't have a stock setup., I have a Holley 4010 square bore 650, soon to be replaced with a Proform 650 double pumper. I currently have just the hose hooked up that goes to the as tank.
Offline hatzie
« Reply #9 on: May 01, 2016, 11:35:41 am »
Some aftermarket carbs have external bowl vents.  They were sometimes vented to the air cleaner.
« Last Edit: May 01, 2016, 11:37:39 am by hatzie »
