Author Topic: Vortec headd  (Read 3718 times)
Offline a.graham52
Vortec headd
« on: April 26, 2016, 07:08:42 pm »
Alright, iv got a set of 062s I want to put on my 77 350. My understanding is my current headers will work, I'll swap my 650 eddy over, and I know I need a vortec specific intake.
My question are, when searching for head and gasket parts, I assume I'm searching for a 99 350 and NOT a 77 350. Also iv read people have the push in rocker studs removed and threaded ones installed. Is it easy to find the right ones?
Offline square81
Re: Vortec headd
« Reply #1 on: April 26, 2016, 09:13:11 pm »
Yeah use the gaskets for the 99 350. The threaded rocker studs hopefully insure the don't come out of the head.
Offline a.graham52
Re: Vortec headd
« Reply #2 on: April 27, 2016, 05:57:53 am »
Is that a Gen 2 or Gen 3? The 99?
Offline square81
Re: Vortec headd
« Reply #3 on: April 27, 2016, 05:02:28 pm »
Dont think the generation matters. I just use gaskets for a 98 chevy pickup with A 350.
Offline a.graham52
Re: Vortec headd
« Reply #4 on: April 27, 2016, 07:42:04 pm »
I'm looking on summit and it seems easier to find some things  when searching by engine family then vehicle
Offline 78BIG-TEN
Re: Vortec headd
« Reply #5 on: April 30, 2016, 09:45:39 am »
The press in studs should be fine unless you are using a really
 high lift cam.Did the heads come with rocker arms?
If not make sure and get the right ones.The Vortecs are self
 aligning.Otherwise heads will have to be machined for
studs and guide plates.As for the springs.the stock ones
are good for I think a .420 lift of maybe it was .460.
Easy to find out with a little research.Others may chime in
in case I missed something or got something wrong.These heads
make a lot of difference on these engines power output.
David
