Author Topic: Technical question...  (Read 4082 times)
Offline philo_beddoe
  • 77 C-10
« on: May 22, 2016, 01:45:31 pm »
What is the reason for engine bolts and the like, to be tightened to a specific torque, such as an intake manifold, heads, pumps, carb, valve covers,,ect. ?
Is it for proper sealing purposes, or is there more to it?
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
Re: Technical question...
« Reply #1 on: May 22, 2016, 04:02:35 pm »
A lot of torques are because if all the bolts are not the same tightness the part that the bolts are holding will warp and leak. Another reason is the bolts will not come loose after time too.
Offline blazer74
« Reply #2 on: May 22, 2016, 04:19:54 pm »
Size of bolt, grade of bolt, material of component(s), gasket.
Environment of said component.
Uniform tightening, warping
« Reply #3 on: May 22, 2016, 07:22:55 pm »
Thread count per inch also affects torque spec.
  • 77 C-10
« Reply #4 on: May 23, 2016, 02:48:29 pm »
Good. Thanks for the input. That makes good sense.
