Author Topic: 85 Silverado door sill plates  (Read 7044 times)
Offline 85c10stepcustom
  • Showstopper
« on: May 22, 2016, 07:50:55 pm »
In an 1985 stepside are the door sill plates the plastic or metal ones ? If you can attach pictures of your 85 sill plates
Re: 85 Silverado door sill plates
« Reply #1 on: May 23, 2016, 08:14:05 am »
they are plastic, mine is a 84 Custom Deluxe but they are all the same
  • Showstopper
« Reply #2 on: June 01, 2016, 08:08:48 pm »
thanks sir
Offline bcstingray
« Reply #3 on: June 04, 2016, 09:51:33 am »
Will the one piece sills fit a 73?
« Reply #4 on: June 04, 2016, 10:13:27 am »
Pretty sure as the floor hasn't changed in the cabs as far as I know...
« Reply #5 on: June 04, 2016, 06:57:40 pm »
they will all fit but a Silverado should have the aluminum sill plates
Offline bcstingray
« Reply #6 on: June 06, 2016, 06:40:42 pm »
I don't believe mine was a Silverado, all it had when I got it was 6 cylinder, 3spd on column, manual brakes and heat. There was no stock carpet or sills in it when I got it.
Customizing the interior to be solid black, so I thought if the newer sills would work I would buy the plastic ones.
