Author Topic: 3" exhaust  (Read 15400 times)
Offline Terryr85
3" exhaust
« on: May 25, 2016, 05:28:21 pm »
Has anyone found a universal bolt on exhaust kit that's 3"? I find a ton in 2 1/4 but never 3". Local shop is between $4-600 to build one and that's with cheap garbage pipe.
73 K20 RC/LB, D60, 14bolt, 5.3l, NV4500
Re: 3" exhaust
« Reply #1 on: May 25, 2016, 05:56:15 pm »
is there a reason behind the 3" pipe? duals or single?
Offline Terryr85
Re: 3" exhaust
« Reply #2 on: May 25, 2016, 06:16:40 pm »
I have a decent 6.0 and I want 3" duals. It's a toy and I wanna make noise with it.
Re: 3" exhaust
« Reply #3 on: May 25, 2016, 07:42:58 pm »
If you want 3" done right it's going to cost you. I'm not aware of any direct bolt in kits for exhaust that will fit without modification. There's too many variables
Offline Stewart G Griffin
Re: 3" exhaust
« Reply #4 on: May 25, 2016, 07:59:25 pm »
Here are my thoughts on 3" exhausts:   If you like 3" then fine, that's all that matters.  Just be aware that 3" might be too big for most engines.
i think i saw a square with a 3" stack exhausts system the other day.  i'll try to take a picture if it's still parked in the same spot.
Re: 3" exhaust
« Reply #5 on: May 25, 2016, 08:29:35 pm »
This is the 3" system on my 74 and I'm sure it cost me ballpark $1800 including the headers. Granted i had everything coated but for just an aluminized system with mufflers, headers and H-pipe expect to spend $1200+
« Last Edit: July 27, 2017, 12:56:25 pm by VileZambonie »
Offline Terryr85
Re: 3" exhaust
« Reply #6 on: May 25, 2016, 08:56:53 pm »
I'm just looking into these universal header back 3" kits, I think that's the best bang for you buck. I'm part of the small percentage that refuses to believe that 3" is ever too big and that I need back pressure.
Offline Funkatation
Re: 3" exhaust
« Reply #7 on: May 25, 2016, 11:26:02 pm »
Nice exhaust vile!!
Offline Surfdude
Re: 3" exhaust
« Reply #8 on: May 26, 2016, 06:23:57 pm »
Vile that is drool worthy!
1978 Chevy C10 Stepside
"Strange things are afoot at the Circle K"
Re: 3" exhaust
« Reply #9 on: May 27, 2016, 08:01:47 pm »
Thanks, it sounds even better than it looks
Offline LTZ C20
Re: 3" exhaust
« Reply #10 on: May 28, 2016, 08:44:16 pm »
That looks great Vile, very nice.
LTZ Cheyenne C20
