Author Topic: Adjust for tb spacer  (Read 3124 times)
Offline Gusgusa1
  • Gasket
« on: June 04, 2016, 04:09:48 pm »
1987 1/2 ton
350 with a throttle body spacer.
The throttle cable binds. The plastic permanently on the cable that goes into the sleave portion binds on the sleave portion. Most of the time need to stand on the gas peddle to get it to move and the start.
Is there a throttle Barack I can get to keep the cable truly horizontal with the carb ??
Please point me in the right direction for this.
2002 gmc 1500hd 6.0 4x4
1987 gmc Sierra classic 1500 350ss 4x4
1986 silverado 350 4x4
1984 scottsdale 305 quad jet 4x4 4spd manual
1982 camaro z28 350 w vortec heads spool
Offline LTZ C20
Re: Adjust for tb spacer
« Reply #1 on: June 04, 2016, 04:54:45 pm »
The best solution is to remove the spacer.
LTZ Cheyenne C20
Offline Gusgusa1
  • Gasket
« Reply #2 on: June 04, 2016, 05:12:14 pm »
Good insight.
Let's assume for a minute I DO NOT want to remove the spacer.
Offline Stewart G Griffin
« Reply #3 on: June 04, 2016, 05:57:34 pm »
Can you post a pic?
« Reply #4 on: June 04, 2016, 06:53:32 pm »
trim the plastic sleeve or compensate the difference by spacing the bracket.
