Author Topic: 82 C20 Squeaking  (Read 2979 times)
Offline 82silvy
82 C20 Squeaking
« on: June 07, 2016, 06:47:46 am »
I have a strange squeak coming from my truck.  It sounds like it is coming from the front, but not 100% sure.  It seems to let up some when brakes are applied, and gets worse when pulling my trailer.  I'm thinking possibly the wheel bearings.  Any thoughts?
Offline 78-OrangeBigTen
Re: 82 C20 Squeaking
« Reply #1 on: June 11, 2016, 04:21:57 pm »
Does it change with speed?  Stop once you get up to a certain mph?  I had the same thing thought it was the front wheel bearings and it turns out it was the speedo cable which is common.  You can try disconnecting the cable from the trans and see if the problem stops.  Also try jacking up the front and spinning each wheel to listen for bearing or brake noise.
Yes this is my truck and no I will not help you move:)
1978 Scottsdale 10 short bed; Big Ten
Originally Ugly Truck, but I love it!
Aka...Tony the Tiger
