73-87 Chevy & GMC Trucks
Air cleaner assy.
Topic: Air cleaner assy. (Read 8621 times)
philo_beddoe
77 C-10
Air cleaner assy.
June 09, 2016, 08:58:00 am »
I have a factory air inlet cover, but a 1977 shows no fresh air duct or snorkel, why is this?
And here is a pic of a 1977 factory set up.
Why do i have the air inlet cover if no factory snorkel? Like the above pic shows.
Last Edit: June 09, 2016, 09:01:12 am by philo_beddoe
Behold, the day of the LORD cometh, and thy spoil shall be divided in the midst of thee. Zechariah 14:1
Re: Air cleaner assy.
June 09, 2016, 01:31:03 pm »
Not sure what you are asking? EFE was standard equipment on GVW 6000 and under.
philo_beddoe
77 C-10
June 09, 2016, 03:56:55 pm »
I think i got it, but i'll point it out next time i stop by. Minor issue.
June 09, 2016, 04:16:21 pm »
Trucks with higher GVW ratings did not require certain emissions items if you are asking why some do and some don't have those items?
philo_beddoe
77 C-10
June 09, 2016, 06:36:58 pm »
What is the purpose of the fresh air duct snorkel anyway, in relation to emissions?
philo_beddoe
77 C-10
June 09, 2016, 06:47:56 pm »
This would work, but i think i would need to cut a hole in the bottom of the neck and weld a sleeve there for the pre heater hose.
http://www.classicindustries.com/product/1977/truck/parts/m3361.html
June 09, 2016, 07:24:52 pm »
Quote from: philo_beddoe on June 09, 2016, 06:36:58 pm
The thermostatic air cleaner allows it to draw heat from the exhaust manifold for faster warm up, lower emissions and better cold engine performance. When the engine warms up it benefits from the cooler denser air charge.
philo_beddoe
77 C-10
June 10, 2016, 07:16:18 am »
"Better cold engine performance", so why ditch the factory set up and go to this? For looks?
June 10, 2016, 11:36:13 am »
Most guys prefer the unrestricted volume for maximum power and cowl induction helps bring the cooler air into the engine compartment which is why they are popular mods. Once you start modifying the engine that little snorkel is like a noose
June 10, 2016, 05:51:03 pm »
with the open air filters like that you will have issues when the engine is cold rich did a little post a while back about them
June 10, 2016, 05:54:57 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=27239.msg226597#msg226597
philo_beddoe
77 C-10
June 10, 2016, 10:37:32 pm »
Thanks, its good to cover the basics now and then.
Air cleaner assy.
