Author Topic: does this ever happen ??  (Read 3192 times)
Offline jg1977c20
« on: June 11, 2016, 01:06:50 am »
so i purchased a set of upper control arms from moog the heavy duty ones complete with new pivot shaft and problem solver ball joint - they have been awesome - but the other day i was looking under the hood and noticed the threads on the passenger side showing , a closer look proved that the end nut that screws into the end of the control arm was unscrewed a good 1/2 inch or so - anyone ever have these things loosen off by themselves ?  1977 c20   these are the shafts without the rubber bushings
« Last Edit: June 11, 2016, 03:24:56 am by jg1977c20 »
1977 c20 cheyenne camper special 8200gvw
Re: does this ever happen ??
« Reply #1 on: June 11, 2016, 01:47:34 pm »
sounds like the nuts weren't properly secured after the alignment.
Offline jg1977c20
« Reply #2 on: June 11, 2016, 03:36:27 pm »
i think your referring to the nuts that hold the control arm and shims to the frame -  i'm talking about the large 1 3/8 " nut that screws onto the end of the pivot shaft right up to the large holes in the arm - theyve been in there for a year and then suddenly the front passenger one was near fully unscrewed
