Quadrajet 17085226
Topic: Quadrajet 17085226 (Read 6022 times)
Fourxbob
Quadrajet 17085226
June 11, 2016, 06:54:14 am »
The two holes for the set screws in baseplate are stripped. Will the baseplate off of a different quadrjet work?
Fourxbob
Re: Quadrajet 17085226
June 11, 2016, 08:47:31 am »
Have a Rochester quadrajet 17085226 with the baseplate stripped for idle set screws. Can I use a baseplate off of a different carb other than the 17085226??
Stewart G Griffin
June 11, 2016, 11:48:27 am »
Hold on--- getting lunch.
Stewart G Griffin
June 11, 2016, 01:02:08 pm »
You could but if the idle passages, vacuum passages etc. don't match then it probably won't work very good.
Stewart G Griffin
June 11, 2016, 01:31:19 pm »
i hear it's an easy repair for the idle mix screw holes.
May want to go over to Cliff's quadrajet forum:
http://www.cliffshighperformance.com/
Fourxbob
June 11, 2016, 09:08:32 pm »
Got a carb off of a 1979. baseplate looks identical to mine. No difference at all. Now it seems the valves are stuck shut on the one I just picked up. Got it soaking in penetrating oil. Fingers crossed.
Last Edit: June 11, 2016, 09:24:32 pm by Fourxbob
blazer74
June 12, 2016, 11:28:11 pm »
Could be the same. Bypass air passages might be different size.
Also the vacuum Ports may be different.
Be careful with the frozen linkage, the shafts easily bend.
Fourxbob
June 28, 2016, 07:05:01 pm »
Got it together. A little grinding on the front passenger side of carb where it was indented for throttle body. But other than that it worked out well. Thànx for the input.
Sent from my XT1526 using Tapatalk
Quadrajet 17085226
