Author Topic: Np203? ? ?  (Read 4223 times)
Offline aarontaylor2008
Np203? ? ?
« on: June 17, 2016, 08:49:10 am »
Recently purchased a new tranny married to a t-case. I believe the t case is a 203 and not sure if it work for my setup. If anyone out there is using a np203 in a mid 80's half ton and did you have to modify anything to bolt up the front drive shaft???
Re: Np203? ? ?
« Reply #1 on: June 17, 2016, 08:58:55 am »
in 77 ish they changed how the driveshaft bolts to the transfer case (yoke vs flange). being you would probably have to reuse the 203 driveshaft it shouldnt matter (due to length difference in the transmission and transfer case) hopefully you got the driveshafts
Re: Np203? ? ?
« Reply #2 on: June 18, 2016, 10:00:47 pm »
No drive shafts just the tranny and tcase, but it does have the flange just like my old old
Sent from my SAMSUNG-SM-N910A using Tapatalk
Re: Np203? ? ?
« Reply #3 on: June 19, 2016, 07:02:30 am »
i did find some measurements on the trans and adapters and transfers cases
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32506.0
Re: Np203? ? ?
« Reply #4 on: June 26, 2016, 07:33:24 pm »
Thanks for the info
