Engine/Drivetrain
clutch replacement 86 4x4 262/3spd
Topic: clutch replacement 86 4x4 262/3spd (Read 3451 times)
Cherg
June 28, 2016, 10:57:21 pm »
About how long to replace the clutch in this pick-up? The mechanic is working out of his garage, and told me that it is easier to remove the engine. What do you think? Thanks
Re: clutch replacement 86 4x4 262/3spd
June 29, 2016, 10:58:56 am »
It's about 7 hours labor including resurfacing the flywheel, new pilot bearing and bleeding the system. I would find a new mechanic.
Cherg
June 29, 2016, 11:57:08 am »
thanks for your advice. I wondered about the wisdom of pulling the engine, as well.
June 29, 2016, 12:01:59 pm »
That makes no sense at all. It is more labor, more fluids, more parts, unnecessary disturbance of the engine etc. Now if you needed additional engine work it may make sense but not if you're just having the clutch replaced.
Captain Swampy
Wisconsin
June 29, 2016, 05:32:49 pm »
Would make sense if you had a V8 to put in.
1987 350TBI 700R4 4X4 4.56 gears 33" BFG All Terrain
Engine/Drivetrain
