Author Topic: Big blocks and header clearance. What's worked for you guys.  (Read 11832 times)
Offline vandy454
Just swapped a 454 into my 73 c10, the guy i bought it from tossed a pair of hedman mid-length headers with it that he had on this motor when we pulled it from his 81 c10 and the don't fit great at all. Passenger side is up against my mini-starter and drivers side is sitting on the clam shell. Sure I could put a few dings in them but they already have a few love taps to clear on the drivers side as it is. at what point will I start sacrificing airflow with dents lol. Good news though, motor fired right up 60psi oil pressure and no bad noises, just the satisfying rumble that pounds through your whole body when you fire up a 500 horse big block with open headers ❤️
What headers have you guys ran?
Specs: 73 c10, mechanical 4spd, 454, stock mounts, stock suspension (eventually going with 3/5 drop)
Offline fitz
Re: Big blocks and header clearance. What's worked for you guys.
« Reply #1 on: July 11, 2016, 03:28:11 pm »
Are you running big block motor mounts?
Offline vandy454
« Reply #2 on: July 12, 2016, 01:36:09 am »
According to my year/make/model/engine on summits website they "fit" a big block
Edit: talking about thE clamshell style ones i ordered.
« Last Edit: July 12, 2016, 01:37:40 am by vandy454 »
Offline big_al273
« Reply #3 on: July 12, 2016, 08:32:04 pm »
https://www.youtube.com/watch?v=azPKIjxmmdU
you can beat the living crap out of headers and have zero real world effect, if they don't fit make em.
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
Offline Engineer
« Reply #5 on: July 13, 2016, 10:34:58 pm »
I tried Hedman. Never again.
I have ran Hooker headers since getting frustrated with Hedman and their no-customer-support-customer-support.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline 73FrankenTruck
« Reply #6 on: July 21, 2016, 01:03:34 am »
I have a 73 GMC C20, w/454. Summit headers (SUM G9011) dropped right in, no rubbing, no modification needed.
-C
Offline ehjorten
« Reply #7 on: July 21, 2016, 08:28:59 am »
I've got Doug Thorley's on my '91 Crew with the 454.  They fit just fine.
-Erik-
Offline Bunkerbuilder
  • OldManOfTheSea.
« Reply #8 on: September 15, 2016, 12:17:20 am »
I run Hooker Headers super compitition headers as I remember them called and had them coated by a place called Caps coatings.
This was when the drive train was a T 400 and a NP205, am hoping the SM465 and or NV4500 I'm installing soon will fit just as well.
I also installed the BBC / 454 frame mounts in place of the 6.2L Diesel frame mounts, not really sure how much of a difference those mount change makes.  Also used the polyurethane in the clamshell motor mounts and the factory engine mount.
Not to go overboard but I also had a plating shop nickel plate the clamshells as I detest rust.
Will update this post with the 4 digit hooked headers part number if possible.
http://www.capscoatings.com/
2007 Chevrolet Silverado K3500
1984 M1028 496,NV4500,NP205.
1986 M1008 6.2L,THM400,NP205. < Was T boned totalled by ins co, parting out.
1986 M1031 MTY DRIVETRAIN
