Author Topic: Fuel Gauge pinned past Full - '81 GMC 2500  (Read 8213 times)
Offline SFP
  • Redneck with a Camera and a Truck
    • Scott Fraser Photography
« on: July 22, 2016, 01:16:59 pm »
Time to tackle first issue with the Farm Truck. 1981 GMC Sierra Grande 2500 Camper Special
The truck as dual tanks, and from research it would appear that both are 20 gallon tanks. Fuel selector works great. Fuel gauge, is pinned past Full for both tanks. At this point I am trying to figure out just how far I can get on a full tank. Starting with the drivers side tank.
Any advice on where to start with figuring out what's wrong? Should I just grab a new gauge and put that in?
Thanks in advance folks.
Scott
'81 GMC Grande Sierra 2500 Camper Special aka Fozzie
Offline Rattler12
  • Old Geezer
Re: Fuel Gauge pinned past Full - '81 GMC 2500
« Reply #1 on: July 22, 2016, 03:54:37 pm »
Direct short between the gauge and the tank sending unit or the wire is broken. Most schematics show it as a tan or blue wire. Mine in my 83 is pink.
83 C-10 shorty 454, 5spd, 3:73 posi
« Reply #2 on: July 22, 2016, 04:11:18 pm »
yours should be pink or tan or orange in color
Offline Burkhalter
« Reply #3 on: July 22, 2016, 06:39:38 pm »
I had that same issue in my 85 K10. It was a poor connection between the gauge and the printed circuit on the back of the instrument cluster.
However I'm not sure if 81 is before or after they went from the direct wiring to the printed wiring.
'85 Chevy K10 361ci sm465
« Reply #4 on: July 22, 2016, 07:55:36 pm »
check that the sending unit connection is not disconnected.
Offline SFP
« Reply #5 on: July 23, 2016, 01:17:59 pm »
Thanks folks. Am going to try to get to it today or tomorrow and will let ya know. Am hoping it's just a disconnected wire or bad ground and not the actual units.
Offline SFP
« Reply #6 on: August 18, 2016, 05:26:09 pm »
SO anyone know how I know without getting them out if I have 2 point or 3 point sending units????
Offline hatzie
« Reply #7 on: August 18, 2016, 10:05:52 pm »
Or the tank ground wire is broken.
Sent from my SM-P605V using Tapatalk
Offline Militiaman55
  • 74 K10 Cheyenne
« Reply #8 on: August 21, 2016, 01:20:34 pm »
I'm not sure what they are calling "points", but on my 74 with a carbureted 350 there are two tubes/ports exiting each sender.  One is the fuel line, the other is a vent line. I believe the fuel injected models have three tubes/ports to incorporate a return fuel line.
Offline Spool
« Reply #9 on: February 23, 2017, 10:12:05 am »
Did you have to replace the printed circuit to fix the issue?
