Author Topic: heater core removal  (Read 27190 times)
Offline philo_beddoe
  • 77 C-10
heater core removal
« Reply #15 on: August 25, 2016, 07:12:08 pm »
Did the heater "corps" after dinner. Thought it was going to be a 3 day project. Did i do something wrong or right? It went in fine. Never had to lower the wheel well. Just the three studs on the firewall.
« Last Edit: August 25, 2016, 09:15:18 pm by philo_beddoe »
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: heater core removal
« Reply #16 on: August 25, 2016, 09:00:41 pm »
Looks fine, I think the only time the lower bolt is an issue is with A/C, the HVAC box sits right there, and would block that lower bolt, requiring the removal of the inner fender.
 1986 Chevy K30(under repair)
  • 77 C-10
« Reply #17 on: August 25, 2016, 09:14:31 pm »
Ok, thanks. I was wondering what all the fuss was about that lower bolt access deal.
Offline blazer74
« Reply #18 on: August 25, 2016, 09:46:45 pm »
I also assumed you had A/C
Offline LTZ C20
« Reply #19 on: August 25, 2016, 11:35:29 pm »
The A/C boxes are a bit more difficult, mine is an AC truck and I was able to do it without dropping the fender, that was a few years ago tho.
LTZ Cheyenne C20
« Reply #20 on: August 26, 2016, 07:47:43 am »
No AC = very easy. Forgot you had a non AC truck. Good job
  • 77 C-10
« Reply #21 on: August 26, 2016, 08:25:01 pm »
Thanks, means a lot coming from you guys. The shop wanted $150. I was determined.
  • 77 C-10
« Reply #22 on: August 30, 2016, 06:12:26 pm »
Now that the ps pump bracket is back in, i could finally start it and test the new core. Clean hot dry air!!
« Reply #23 on: August 30, 2016, 06:51:34 pm »
You know you could run it without the power steering pump belt on.
  • 77 C-10
heater core removal
« Reply #24 on: August 30, 2016, 07:49:09 pm »
Yes, but i was too lazy to remove the alt belt in order to remove the ps belt. Couldnt start it with the ps belt dangling there.  It was nice to start it with everything fixed and complete.
« Last Edit: September 01, 2016, 03:53:55 pm by philo_beddoe »
Offline redhot1.4
« Reply #25 on: August 31, 2016, 03:13:01 pm »
Holy cow
 I've got a job lined up in front of me. Yes my truck has ac. But doesn't work at the moment it will before next summer rolls around. THIS Texan would rather have a working heater lol
Sent from my SAMSUNG-SM-G870A using Tapatalk
  • 77 C-10
« Reply #26 on: August 31, 2016, 05:24:06 pm »
Heater in TX??
Offline Jason S
« Reply #27 on: September 01, 2016, 08:57:00 am »
  Good job.  Is that an aluminum heater core?
  • 77 C-10
« Reply #28 on: September 01, 2016, 03:52:44 pm »
I believe so. It was a Murray brand. O'rielly. $26.
