Author Topic: heater core removal  (Read 27174 times)
Offline NCali
heater core removal
« on: July 22, 2016, 07:37:09 pm »
I read the procedures on removing the heater core in the tech section
my question has to do wit this
Remove nuts at selector duct studs (projecting through firewall). Remove selector duct to firewall screw.
I see two studs comming through the firewall
does the inner fender have to come out to get to the bolts on the bottom side of the heater box?
Black Labs Matter
Re: heater core removal
« Reply #1 on: July 22, 2016, 07:58:17 pm »
Either drop it to gain access or remove it altogether. Removing it makes getting in there easier but it depends on what your abilities are as to whether or not you can sneak it out without destroying everything including yourself.
Offline frotosride
    • WFO CONCEPTS
« Reply #2 on: July 22, 2016, 09:25:54 pm »
Removing the fender well is a huge help!  Mostly because you don't have to completely slump over the hood the whole time and those bottom nuts are square t best.
Offline NCali
« Reply #3 on: July 22, 2016, 09:28:29 pm »
that just took the "easy " right out of this job
but thanks
Black Labs Matter
« Reply #4 on: July 23, 2016, 08:00:58 am »
If you want easy, the easiest way to do it is to drop it off to a mechanic and pick it up when it's done.  :D
Offline roundhouse
« Reply #5 on: July 23, 2016, 09:40:08 am »
You will never get the bottom corner bolt out without removing the inner fender
Unless like me.   You drill a 1" access hole in the inner fender
Offline philo_beddoe
  • 77 C-10
« Reply #6 on: August 23, 2016, 12:24:56 pm »
Ok. So how do you drop that inner fender well?
Offline big_al273
« Reply #7 on: August 23, 2016, 02:46:10 pm »
15 or 16 bolts around the front, rear and wheel well edges of the inner fender, you don't need to pull it out just drop it down to sit on the tire until reassembly. Putting the inner fender back in will be easier with an extra set of hands to hold it while you thread in bolts but it can be done by yourself.
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
« Reply #8 on: August 23, 2016, 04:35:09 pm »
9/16" and 1/2" 6 point sockets. Disconnect and remove the battery altogether.
Offline blazer74
heater core removal
« Reply #9 on: August 23, 2016, 06:17:20 pm »
Get yourself some penetrating oil and spray in side the holes where the nut plates are, depending on how much rust buildup on the bolts you don't want to twist a nut plate off for the inner fender.
  • 77 C-10
« Reply #10 on: August 23, 2016, 07:01:47 pm »
Will do! Busted plenty of nuts and bolts in my day. Including one finger not long ago.
  • 77 C-10
« Reply #11 on: August 24, 2016, 10:26:43 pm »
Ok, but the battery doesnt seem to be in the way of anything.
  • 77 C-10
« Reply #12 on: August 24, 2016, 10:33:31 pm »
I may entertain the idea of drilling an access hole. Then just close it up with a piece of steel and some black rtv, nice and neat and flush of course.
Unless VZ highly recommends not to.
« Reply #13 on: August 25, 2016, 08:00:10 am »
Disconnect the battery, remove it and clean the area and battery/tray. Drop the inner fender, clean everything. Those areas are prone to corrosion so kill two birds instead of taking a shortcuts and poking holes.
  • 77 C-10
« Reply #14 on: August 25, 2016, 08:21:48 am »
Ok, but a short while back I installed a new battery tray and bracket and cleaned all in there, painted nice and then coated with anti rust stuff. I'm always checking the nooks, crannies and crevices for "junk".  I need to do this thing fast and make it go away. I admit, I don't like poking holes in truck. I also admit, every time I do a project..unforeseen problems stop me dead in my tracks and I end up texting you to bail me out, and full of anxiety and worries. lol
