Author Topic: Distributor and Rotor issue?  (Read 4303 times)
Offline Harmon
« on: July 28, 2016, 12:51:49 pm »
1986 chevrolet c/10
I have had an issue with the truck not starting occasionally. It will turn over and the starter will work but it acts as if there's no spark.  A couple of years ago I replaced the entire distributor , all the parts , cap and rotor.
Not much longer after that it did the same thing , so I took off the distributor cap and rotor and clea n them. If I do that almost every single time the truck will start. Has anyone had an issue with this? I finally bought a lifetime warranty this  cap and rotor because of this issue but it makes me very weary of driving the truck as I do not want to be stranded.  I do keep a back up rotor in my truck just in case though.
 Any ideas of my issue or similar problems would be greatly appreciated thank you.
Offline Burkhalter
Re: Distributor and Rotor issue?
« Reply #1 on: July 28, 2016, 01:07:10 pm »
How do the wires look going into the distributor? Have you double checked your timing? Have you tested the coil both cold and warm? A while ago I had a problem with my coil not working when it was warm.
'85 Chevy K10 361ci sm465
Offline Harmon
« Reply #2 on: July 28, 2016, 01:15:30 pm »
My timing is off so when it runs again I'm going to adjust it.  Would timing cause no spark symptom?
Offline Burkhalter
« Reply #3 on: July 28, 2016, 08:06:14 pm »
You would still have spark. You just wouldn't be getting spark at the right time.
« Reply #4 on: July 29, 2016, 04:25:21 pm »
Check the pick up coil and ignition module
