Author Topic: 454 egr delete/ issues/ bypass  (Read 9079 times)
Offline thelincolnguy
« on: July 30, 2016, 08:08:32 am »
Hello everyone. I have a 1986 chevy c30 single cab 454 with the awful egr system. As i am aware this system has two pumps. The bottom side pump being the smog pump. I need to know if anyone has the part number to a serpentine belt that will bypass the smog pump after i remove the pully. (Will not clear otherwise) my smog pump has locked up and wont spin until i get on the highway. Going thru belts like crazy and plan to do a full egr delete in the future. (New heads,intake, headers, etc. ) any easy temporary fix is helpful as this truck is my daily driver (65 miles round trip a day)
Thelincolnguy
Re: 454 egr delete/ issues/ bypass
« Reply #1 on: July 30, 2016, 08:45:47 am »
Your EGR and your A.I.R. pump are two different systems. Just look up your belt by application with or without ac, with or without A.I.R.
« Reply #2 on: July 30, 2016, 11:42:35 am »
The a.i.r. Pump is the one causing problems. And my truck has a/c. the serpentine belt is the one that needs to be shorter
Thelincolnguy
« Reply #3 on: July 30, 2016, 03:12:25 pm »
Just run a string around the pulleys and measure. Try a 530K6
« Reply #4 on: July 30, 2016, 04:01:40 pm »
Ok i will try it. Should i put a string around it with the current belt on and tensioned? The alternator tensions it. No auto tensioner
Thelincolnguy
« Reply #5 on: July 30, 2016, 06:10:45 pm »
Yes
