Body, Glass & Paint
Hood Popping
Topic: Hood Popping (Read 14572 times)
123 pugsy
Hood Popping
May 02, 2006, 09:20:00 pm »
Driving along and go over a bump and the hood pops up to the safety catch.I used lithium grease on it before I installed it and I've loosened the pin (brought it down) and moved it around (left,right front,back) and still pops.Anyone have this problem before?
Pugsy
76 C10 LWB
TPI 350
Re: Hood Popping
May 02, 2006, 08:51:00 pm »
you need to adjust your striker on the hood. Loosen the Jam nut and adjust it a little longer.
Blazin
Blazin new trails!
Re: Hood Popping
May 02, 2006, 10:41:00 pm »
Hood latch new? if not it might be junk. I played around trying to adjust a few of mine, when I got fed up and put a new one in it fixed the problem.
123 pugsy
Re: Hood Popping
May 03, 2006, 04:16:00 am »
Adjusted the jam nut already.Moved it around.Must need replacing.Also,its not new,came with the truck so I don't know if it was working before.
Pugsy
76 C10 LWB
TPI 350
Re: Hood Popping
May 03, 2006, 05:06:00 am »
Lube it good with penetrating oil instead
Blazin
Blazin new trails!
Re: Hood Popping
May 03, 2006, 07:09:00 am »
I just bought a new one from GM for my 86 it was like $22& change. I am going to order one for my 79 this week cause its a piece of crap too.
123 pugsy
Re: Hood Popping
May 03, 2006, 09:08:00 am »
I'll take it off and remove the grease ,see what happens because it is quite slippery.Maybe too slippery and it shakes easily over the bumps.
Pugsy
76 C10 LWB
TPI 350
Re: Hood Popping
May 03, 2006, 04:07:00 pm »
Are your rubber bumpers up too high?
123 pugsy
Re: Hood Popping
May 03, 2006, 06:32:00 pm »
Its not that.I've brought the cam nut down a lot with it quite loose and still does it.I've taken it out and removed all the grease at this point ,just gotta go for a test drive.
Pugsy
76 C10 LWB
TPI 350
123 pugsy
Re: Hood Popping
May 03, 2006, 06:55:00 pm »
Test drive: No good.I'll have to buy a new one.
Pugsy
76 C10 LWB
TPI 350
DnStClr
Re: Hood Popping
May 03, 2006, 08:34:00 pm »
I was just cruisin Ebay...
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8061939026&fromMakeTrack=true
Oh- I just remembered- your truck is older.
Edited by:
DnStClr
at: 5/3/06 7:39 pm
Don
87 Chevy Silverado
OKUMA111
Re: Hood Popping
May 03, 2006, 11:04:00 pm »
try checking your release cable , maybe its getting stuck at a point which will release the mechanism. try lubricating the cable .
123 pugsy
Re: Hood Popping
May 04, 2006, 04:48:00 am »
Thanks for all the tips guys.I forgot to mention its a 76 with no cable.
Pugsy
76 C10 LWB
TPI 350
Body, Glass & Paint
Hood Popping
