Author Topic: The two prong oil sender near the oil filter...  (Read 3917 times)
Offline Stewart G Griffin
« on: August 14, 2016, 05:47:22 pm »
i can't get the plug to fit snugly over the sender and stay on:
It's Borg Warner # S695
Is there a sender that is a little smaller up top in the black area?
NOTE: the one in the pic is actually the one that came with the 4.3 but same problem.  In this case it's 1/8" npt and was located near the distributor and since the plug was on top i didn't have problems with it coming off.  Now that i'm running it near the oil filter, the plug won't stay on and can't get it to go on all the way anyway.
« Last Edit: August 14, 2016, 05:51:37 pm by Stewart G Griffin »
Re: The two prong oil sender near the oil filter...
« Reply #1 on: August 17, 2016, 03:12:11 pm »
have you tried to use a degreaser on the rubber to get some of that oil off?
« Reply #2 on: August 17, 2016, 08:21:36 pm »
What type and brand should i use?
« Reply #3 on: August 17, 2016, 08:39:36 pm »
me personally would use brake cleaner for the outside parts sprayed on a rag then wipe. Im sure theres a “proper” cleaner like
http://www.autozone.com/miscellaneous-cleaners-and-degreasers/electrical-parts-cleaner
« Reply #4 on: August 17, 2016, 08:48:37 pm »
Those connectors used to be nice and pliable.  With age they have gotten hard and shrunk.
« Reply #5 on: August 17, 2016, 11:46:30 pm »
Standard Motor Products S939
Pair the two blue wires to one terminal and the pink wire to the other.
