Author Topic: 86 Pickup Tailgate trim mounting template??  (Read 6581 times)
Offline 86 NH BOWTIE
« on: August 17, 2016, 05:51:13 pm »
Hello, very first post, hope its in the right place. I have a 86 k-10 short bed and I have the brushed tailgate trim and am wondering if there is a mounting template available for getting the holes right.
1986 K-10 Shortbox 305cid Turbo 700R4
1972 Pontiac LeMans GT 400cid 4BBL 4 SPD.
Offline LTZ C20
Re: 86 Pickup Tailgate trim mounting template??
« Reply #1 on: August 17, 2016, 09:37:11 pm »
No template that I know of. You could separate the two halves, mark new holes and put it back together. It will separate, just to be brutal on it, I've separated and re attached them a few times. I would offer to measure mine for you but I'm not in the same place as my truck is.
LTZ Cheyenne C20
Offline AZ4X4SQBDY
« Reply #2 on: August 17, 2016, 11:17:45 pm »
I've got one of those panels in my office and was thinking you could put the screws in backwards or from behind the panel so they are sticking out and then line the panel up and gently scratch the areas that you need to drill the holes.
1987 GMC Sierra Classic 4x4 short, fleet, 1985 Chevrolet Silverado 4x4 short, step side, '87 Chevy Silverado short fleet, '91 Dodge Ramcharger LE 4x4,
2005 Porsche Boxster S,1982 Alfa Romeo Spider Veloce
« Reply #3 on: August 18, 2016, 04:32:27 pm »
Thanks a lot for the suggestions. After doing a little bit more sizing up, it appears as though the 4 mounting screws may line up dead center in the 4 stamped squares on the inner tailgate. Sort of makes sense. Just working up the guts to drill into a perfect surviving tailgate from 86! I will update no matter how it works out.
« Reply #4 on: August 18, 2016, 05:10:10 pm »
Just make a template with a piece of construction paper.
« Reply #5 on: August 18, 2016, 05:29:27 pm »
Hmm. once again, simplicity wins out over long drawn out math! Good idea, thanks!
Offline LTZ C20
« Reply #6 on: August 18, 2016, 10:17:15 pm »
The holes do line up in the center like your thinking just so you know.
LTZ Cheyenne C20
« Reply #7 on: August 19, 2016, 12:23:34 pm »
Thanks for the confirmation LTZ C20!!!
Offline LTZ C20
« Reply #8 on: August 19, 2016, 07:07:49 pm »
Welcome. I'll be home in about an hour if you would like me to measure my tailgate.
LTZ Cheyenne C20
« Reply #9 on: August 22, 2016, 01:29:30 pm »
Worked perfectly. all 4 holes are centered within their respective squares. Will post pics. Thanks again!
« Reply #10 on: August 22, 2016, 01:44:11 pm »
I guess my pics are too big.  :-[
Offline LTZ C20
« Reply #11 on: August 22, 2016, 01:51:16 pm »
Even without pics, it still worked.
LTZ Cheyenne C20
