Author Topic: 74 c10 vent window!  (Read 3568 times)
Offline vandy454
74 c10 vent window!
« on: August 17, 2016, 11:39:28 pm »
Finally getting around to tackling the dreaded squarebody drivers side vent window. My lower pivot point is sheared off and the stud looks pretty bad, pretty sure the nut isn't coming off. I have been searching and searching not finding any parts for these. Has anyone tried to drill this our and run a bolt through it to make it operational again?
Needing some advise as this is the first squarebody I'm restoring!
Re: 74 c10 vent window!
« Reply #1 on: August 18, 2016, 05:09:01 pm »
You'd be better off finding another used rebuildable unit. The angle needs to be precise for proper fitment and sealing. Your other option is to use 81-87 vent windows which parts are more readily available.
Offline vandy454
« Reply #2 on: August 20, 2016, 11:55:39 am »
Are they a direct fit replacement ?
