Author Topic: Foggy and steamy inside cab!  (Read 8359 times)
Offline philo_beddoe
  • 77 C-10
« on: August 23, 2016, 07:18:51 am »
....and it smells a little like anti freeze, and the rag i used to wipe windows tasts sweet.  (For the record i only dabbed my tounge).  Help, need to fix fast.  Thanks
My guess is heater core leak?
Offline Jason S
Re: Foggy and steamy inside cab!
« Reply #1 on: August 23, 2016, 07:56:45 am »
Sounds like a leaky heater core to me.
  • 77 C-10
« Reply #2 on: August 23, 2016, 08:11:00 am »
How do i access. I have no a/c.
  • 77 C-10
« Last Edit: August 23, 2016, 12:26:45 pm by philo_beddoe »
Offline Jason S
« Reply #4 on: August 23, 2016, 08:51:18 am »
It looks like you posted the VileZambonie procedure: http://forum.73-87chevytrucks.com/smforum/index.php?topic=1949.msg8379#msg8379
Here's another link:http://forum.73-87chevytrucks.com/smforum/index.php?topic=33480.msg284468#msg284468
The procedure is also in the service manual: http://forum.73-87chevytrucks.com/smforum/index.php?topic=30115.msg252586#msg252586
Off the top of my head (it's been a long time since I had to replace one), the hardest part seemed to be gaining access to the lowest heater box stud that goes through the firewall. It may be easier to drop the inner fender a bit.  Once the nuts are removed from the heater box studs, it all slides back under the dash.
Here's a photo of the engine side of the firewall.  You can see the approximate location of the heater box studs (you may have to scroll down a bit):http://forum.73-87chevytrucks.com/smforum/index.php?topic=21690.msg179454#msg179454
« Reply #5 on: August 23, 2016, 08:51:50 am »
lol cant say dont do this. cause i tasted someones oil off their dipstick to "tell" them how many miles were left of the oil life
  • 77 C-10
« Reply #6 on: August 23, 2016, 12:17:11 pm »
Yah, lol. Sometimes ya gotta do things the ugly way to know for sure.
  • 77 C-10
« Reply #7 on: August 23, 2016, 12:31:27 pm »
So why does all that stuff have to come off the firewall, and not just the two hoses? Doesnt the core come through the cab? 1st timer.
Offline Jason S
« Reply #8 on: August 23, 2016, 01:04:59 pm »
The under dash box is what is bolted to the firewall, as well as attached to the defrost ductwork.  The heater core itself is within box under the dash.
You need to unbolt and remove the box from the firewall and open it up to gain access to the heater core.
It's also a good time to clean out any trash that has accumulated inside the box (e.g., pens, gum wrappers, dirt, etc.)
  • 77 C-10
« Reply #9 on: August 23, 2016, 02:36:07 pm »
Ok, makes sense. Can i by-pass the core while i work on it, and still drive  Obviously no heat.
Online zieg85
« Reply #10 on: August 23, 2016, 03:03:43 pm »
Yes you can by-pass it but don't wait till it gets too cold to do it.(talking from experience)
  • 77 C-10
« Reply #11 on: August 23, 2016, 05:59:01 pm »
Ok, got it.
  • 77 C-10
« Reply #12 on: August 23, 2016, 07:49:09 pm »
Fyi...i'll continue this heater core project post on the other post, "heater core removal". So as not to double up.
