Author Topic: Sound deadener  (Read 13359 times)
Offline Als87
Sound deadener
« on: August 26, 2016, 04:20:45 pm »
Any tips on what to use for sound deadener? I don't have a radio right now in the truck so that's not the issue. It's all road noise, engine noise. There's no insulation inside the truck right now but I'm looking for stuff that has worked well for u guys before I decide what to buy. Thanks in advance.
'87 Shortbed 4x4
350, 350thd
4" suspension lift on 35's
Offline harcorshe
Re: Sound deadener
« Reply #1 on: August 26, 2016, 09:02:41 pm »
 I used Dynamat. Covered the floor, the roof, and inside the doors. Made a huge difference.
'78 K20
454
TH400
14 Bolt
205 Transfer Case
Offline Als87
Re: Sound deadener
« Reply #2 on: August 26, 2016, 10:51:29 pm »
Thanks, I figured Dynamat was the way to go but didn't kno if cheaper versions were worth messing with. I plan on doing the whole floor, inside the doors & the firewall. How much did u need?
'87 Shortbed 4x4
350, 350thd
Re: Sound deadener
« Reply #3 on: August 27, 2016, 08:09:30 am »
Offline OldGray
  • Ne'er-do-well
Re: Sound deadener
« Reply #4 on: September 07, 2016, 12:26:04 pm »
This is the (very effective) "poor man's dynamat"   ;D
Used it on the inside of my doors and it really knocked down the noise.
http://www.lowes.com/pd/Peel-Seal-Instant-Waterproof-Repairs-6-in-x-25-ft-Aluminum-Roll-Flashing/1018733
1979 Chevrolet Bonanza / 305 / LWB
Offline Als87
Re: Sound deadener
« Reply #5 on: September 07, 2016, 03:27:48 pm »
dang, that is cheap! & It really worked that good?
'87 Shortbed 4x4
350, 350thd
Offline OldGray
  • Ne'er-do-well
Re: Sound deadener
« Reply #6 on: September 07, 2016, 05:16:30 pm »
Worked well for me.
If you Google Dynamat and Peel & Seal you will see a lot of conversation on it.  As far as me, I'm not paying for Dynamat, that's for sure.
I applied a few strips to the inside of the outer door skin and the difference was pretty noticeable, and I didn't even completely cover it.
https://www.google.com/search?q=dynamat+%22peel+%26+seal%22&ie=utf-8&oe=utf-8
« Last Edit: September 07, 2016, 05:18:10 pm by OldGray »
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
Re: Sound deadener
« Reply #7 on: September 07, 2016, 05:52:53 pm »
Well I know I will be going to Lowes   :)
Offline Als87
Re: Sound deadener
« Reply #8 on: September 07, 2016, 08:49:44 pm »
Right on. Thanks old gray. I'll b going soon
'87 Shortbed 4x4
350, 350thd
Offline OldGray
  • Ne'er-do-well
Re: Sound deadener
« Reply #9 on: September 08, 2016, 04:36:15 pm »
Happy to help!
Be sure you get it where you want it before it goes down, because it sure isn't coming back off easily!
Offline MrFiveOh
  • The Local Po-Po
Re: Sound deadener
« Reply #10 on: September 09, 2016, 09:10:09 am »
Ill second this, stuff works great and is cheap. If it wasnt suggested, I would used this to help seal between each layer you put side by side. it will look clean and professional.
http://www.homedepot.com/p/Nashua-Tape-1-89-in-x-50-yd-322-Multi-Purpose-HVAC-Foil-Tape-1207792/100030120
1974 C-10 AKA "Smurf"
Offline ehjorten
Re: Sound deadener
« Reply #11 on: September 27, 2016, 07:40:51 am »
Peel and Seal is an asphalt-based product and as such is really a poor choice for interior sound deadening!  Is it cheap?  Yes it is!  Will it stink-up your interior?  Yes it will!  Will it dry-out and become brittle, lose its effectiveness and lose its adhesion with time and heat?  Yes it will!
B-quiet is a good Butyl rubber based sound deadener that is comparable to Dynamat at a lower cost.  Do some reading about asphalt-based sound deadener and make your own choice, but it really is not a good choice for the interior of your ride.
-Erik-
Offline MrFiveOh
  • The Local Po-Po
Re: Sound deadener
« Reply #12 on: September 27, 2016, 11:30:25 am »
Peel and seal is asphalt based, but is does not stink or lose adhesion in the heat. There are thousands of guys in Texas that use this material or one similar from Home Depot on these trucks all the time. No complaints about it. just like anything else, preparation is key when installing this.
Offline aaronboss221
Re: Sound deadener
« Reply #13 on: September 29, 2016, 07:00:02 pm »
Search mrwhitels1 on YouTube. He uses something I can't recall bit doesn't have stink or anything. Go watch his video. You will get a lot of info from it.
Sent from my SM-G930V using Tapatalk
Offline SinisterC10
Re: Sound deadener
« Reply #14 on: September 30, 2016, 02:38:02 pm »
This guy is a member on our nastyz28.com Camaro forum. Some of the major US automotive companies use his product for their vehicles.
http://www.carinsulation.com
