Author Topic: MPG, Part 2  (Read 105099 times)
Re: MPG, Part 2
« Reply #120 on: March 19, 2020, 07:50:34 am »
be cautious of the AFM on those causing collapsed lifters. from what i understand its not a matter of "if" but "when", its somewhat of a easy fix and you might be able to luck out and prevent it from happening. theres a few youtube vids on it
https://www.youtube.com/watch?v=pP7I5tbXsfw
you can even disable it. that whole thing about dropping to 4 cylinders sounds good but imo isnt practical. also you might notice your battery volts dropping to 12.8 or so and this is normal and GMs attempt to save some millage
Offline Stewart G Griffin
Re: MPG, Part 2
« Reply #121 on: March 20, 2020, 09:14:23 pm »
i don't think the LH9 5.3 has any of that "AFM" stuff.   It does have variable valve timing and flex fuel capability.   i need to brush up on my LS knowledge.  i've been very busy lately.
i hear AFM/Displacement on demand isn't good for the engine long-term.  All these tricks to try to get mpg don't seem to pay off in the long run?    The turbo 4 in the silverado can't tow as well as the 4.3, 5.3 etc.    i will  try to locate the article concerning DOD not being good for the engine long-term.
Diesel seems to work great for towing, but then there's the high-initial cost which may never pay for itself unless you do a ton of driving.
You can't change the laws of physics.......
« Last Edit: March 20, 2020, 09:18:38 pm by Stewart G Griffin »
Re: MPG, Part 2
« Reply #122 on: March 28, 2020, 02:36:53 pm »
Still on the colorado
271 miles / 16.25 gallons = 16.68
OH NO.......
$2.599 per GALLOn regular at exxon,  $42.24 to fillup.
Now, i was late one day for work, so i was kind of hammering it and maybe that affected it.  Side note at 75 it still rpms below 2500rpm.
Re: MPG, Part 2
« Reply #123 on: April 04, 2020, 06:22:35 pm »
colorado
317.5 /  16.63 gallons =  19.02 mpg
$2.099 per gallon regular at exxon.   $34.91 to fillup
Re: MPG, Part 2
« Reply #124 on: May 15, 2020, 06:34:08 pm »
colorado
329.7 miles / 18.067 gallons = 18.24 mpg
$1.859 per gallon regular at exxon,   $33.59 to fillup
i was late one day for work.  i think the colorado is speed limited to  99/100 mph?   i can't confirm this.
i discovered that the 5.3 LS DOES have some top end.
Offline fitz
Re: MPG, Part 2
« Reply #125 on: May 21, 2020, 08:48:04 am »
With the long weekend coming up have you considered dropping the 4.3 in the Colorado and checking the mpg's?. Ha ha, how are you enjoying the Colorado so far?
