Author Topic: Wheel spacers  (Read 5027 times)
Offline Als87
Wheel spacers
« on: August 27, 2016, 03:05:29 pm »
Considering adding wheel spacers this week. 4wd lifted truck so do I need the same size in front & back? Has anyone had good or bad experience w any different brands or w wheel spacers overall. I don't want to go out to far but I like the kicked out look w fender flares. Thanks
'87 Shortbed 4x4
350, 350thd
4" suspension lift on 35's
Re: Wheel spacers
« Reply #1 on: August 27, 2016, 05:04:56 pm »
Is this for your 87 V10? If so just get them for the back. 2" on each side will do it.
Offline Als87
Re: Wheel spacers
« Reply #2 on: August 27, 2016, 05:48:02 pm »
Yea it is. So could I go 2" on the back & 1" in the front? Or 3" & 1"???
'87 Shortbed 4x4
350, 350thd
Offline LTZ C20
Re: Wheel spacers
« Reply #3 on: August 27, 2016, 09:00:11 pm »
Anything above 2" is unsafe, in general I would never use wheel spacers at all. Larger than 2" allows for the possibility of the wheel flexing away from the axle especially if the lug nuts are not tightened the the correct torque rating and if they are over tightened it could cause to much stress on the studs, causing them to snap or break at the most inconvenient time, like driving down the freeway.
LTZ Cheyenne C20
Offline Als87
Re: Wheel spacers
« Reply #4 on: August 27, 2016, 11:10:28 pm »
Ok yea I don't want unsafe, so I'll def just stick to the 2" max & make sure they're properly torqued. Thanks
'87 Shortbed 4x4
350, 350thd
