Author Topic: Looking fora Part, Upgrading radiator  (Read 5825 times)
Offline MrFiveOh
  • The Local Po-Po
« on: September 05, 2016, 12:59:13 pm »
I currently have a SBC radiator, I have a new radiator, fan shroud and mounting plate that goes to a BBC. These parts are all interchangeable for 73-79 trucks.
The issue i am running into is mounting the top plate that goes over the BBC radiator. I have holes for the bolts but there in nothing in the hole to properly fasten the bolts to ( i figure there would be a threaded insert of some sort.) My question is does anyone know where i can find these parts i need to mount this top radiator bracket?
Top panel : http://www.oreillyauto.com/site/c/detail/TDP0/8673/7034P.oap?year=1978&make=Chevrolet&model=C10%2BPickup%2BRWD&vi=1030318&ck=Search_7034P_1030318_602&pt=7034P&ppt=C0095
4 holes where bolts are supposed to secure the top panel
http://dannix.net/public/pics/83k10chevy/frontclip/frontclip27.JPG
Thanks
« Last Edit: September 05, 2016, 02:27:01 pm by MrFiveOh »
1974 C-10 AKA "Smurf"
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
Re: Looking fora Part, Upgrading radiator
« Reply #1 on: September 05, 2016, 05:07:47 pm »
I have been looking for the inserts too.
Offline MrFiveOh
  • The Local Po-Po
« Reply #2 on: September 05, 2016, 05:15:21 pm »
If i happen to find something before i get an answer, Ill let you know
Offline 80Chevy4x4
« Reply #3 on: September 05, 2016, 07:56:20 pm »
Thanks a million!!!!!!
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #4 on: September 06, 2016, 08:08:40 am »
My front panel has 4 captured nuts, these would be welded in. I think the only solution fir your situation is a rivet nut/rivnut
Sent from my LGL34C using Tapatalk
 1986 Chevy K30(under repair)
Offline ck80
« Reply #5 on: September 08, 2016, 04:30:46 pm »
Dumb question as I'm away from my square bodies at the moment (theyre at the other house), but, would some of the gm clips work for what you need? They come in varying diameter and we're used in the late 70s through 80s at least on areas like the core supports, fenders, bumper mount braces, etc.
Offline MrFiveOh
  • The Local Po-Po
« Reply #6 on: September 13, 2016, 10:35:05 am »
Those wouldnt work, there would be no way to placed them inside the hole  and secure them in place. They would have to go into these holes.... http://dannix.net/public/pics/83k10chevy/frontclip/frontclip27.JPG
« Reply #7 on: September 13, 2016, 11:40:34 am »
Jack nuts
