Author Topic: Tach move?  (Read 6194 times)
Offline Tazman
Tach move?
« on: September 09, 2016, 08:54:35 pm »
I have had an aftermarket tach in my truck for several years, I think it comes very handy in helping to keep the truck running right. I have had it mounted to the column and recently I mounted it directly to the front of the dash just left of the clock. I am thinking of mounting it in the dash where the clock is currently and does not work anyway. I believe it will fit nicely because the size is about the same. Yet at the time I do not know how to keep it in place. I was wondering if anyone else has done this.
Thanks
God BLESS AMERICA
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Tach move?
« Reply #1 on: September 10, 2016, 05:57:38 am »
I put a boost gauge in the lower left spot(most likely where your clock is) it did require some cutting of the cluster. Give me a few hours and I'll be able to get you a few pics
 1986 Chevy K30(under repair)
Re: Tach move?
« Reply #2 on: September 10, 2016, 09:21:13 am »
Here are some pics, I was trying to do the least destructive methods, but my need to want a gauge in that spot over ruled my decision to not hack away.
The other way I have seen it done is to cut the actual overlay little by little till the gauge slides in but doesn't fall through, only thing with that is the gauge is now at a separate level over the other gauges and it looks weird.
Offline Tazman
Re: Tach move?
« Reply #3 on: September 10, 2016, 01:01:57 pm »
Looks pretty good,I will do mine and let you know how it works out.
Thanks
God BLESS AMERICA
Offline 79ScottsdaleGuy
Re: Tach move?
« Reply #4 on: April 21, 2017, 09:49:50 am »
I converted my 1979 Scottsdale from idiot lights to guages with factory tach.  Pretty happy with the results!
1979 Chevrolet Scottsdale C10 Auto 3 speed Non-A.C.
