Author Topic: Edelbrock 1406 carb  (Read 11526 times)
Offline dar06003
Edelbrock 1406 carb
« on: September 14, 2016, 09:55:42 pm »
I'm trying to install an edelbrock 1406 carb on my 84 C10 Silverado. The old carb was a quadrajet that had three linkages to three different cables on the drivers side of the carb. Obviously one is the throttle, I've gathered one of the other two is an auto transmission kickdown cable? Is that right? What is the third cable?
Offline dar06003
Re: Edelbrock 1406 carb
« Reply #1 on: September 14, 2016, 10:05:14 pm »
Offline dar06003
« Reply #2 on: September 14, 2016, 10:08:37 pm »
You can see two of the cables in this pic of the old carb, the third cable is hidden behind and underneath the two visible ones
Offline dar06003
« Reply #3 on: September 14, 2016, 10:09:47 pm »
Offline Stewart G Griffin
« Reply #4 on: September 14, 2016, 10:10:26 pm »
Probably cruise control?
Offline dar06003
« Reply #5 on: September 14, 2016, 10:36:17 pm »
So it's actually the linkage in that last pic, the one with the metal rod that's hooked through whatever that circular thing is next to the brake booster. That's the one I don't get
Offline dar06003
« Reply #6 on: September 14, 2016, 11:09:40 pm »
Yeah I believe you're right Stewart, that's the cruise control servo I guess. Does anyone know where the vacuum lines coming out of the cruise control servo connect?
Offline dar06003
« Reply #7 on: September 15, 2016, 04:04:19 pm »
Am I downgrading my carb by going from a stock quadrajet to an edelbrock 1406?
Offline boulky12
  • Dallas, TX Daily Driver
« Reply #8 on: September 15, 2016, 05:08:29 pm »
The quadrajet does have a higher CFM capability but on a smallblock with a few upgrades, it won't be a downgrade.
If it was a Built Big Block it would be a downgrade.
86 Swb GMC, 2/2 drop, stock 305/350, Quadrajet, Dual Tanks, 3.08 gears, Rally wheels
Offline Flyinhillbilly
« Reply #9 on: September 15, 2016, 05:30:09 pm »
Edelbrocks are great carbs. I ran them for years. As long as you keep the trash and water out of them, they are basically maintaince free.
I was born on a mountian, raised in a cave,
Overpowered cars is all I crave.
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
« Reply #10 on: September 15, 2016, 06:05:51 pm »
Edelbrocks are actually the old Carter carbs...Edelbrock bought Carter out and back then Carter was a very good carb....i ran 2 of them on a 1970 Dodge charger with a 440 and she would tear up the roads.
Offline dar06003
Edelbrock 1406 carb
« Reply #11 on: September 15, 2016, 09:36:13 pm »
Is the choke plate supposed to be wide open when you start the engine up? It sounds like I have the pedal stomped to the floor immediately after I start the truck, and the choke plate is wide open
Offline LTZ C20
« Reply #12 on: September 15, 2016, 11:18:14 pm »
An expertly tuned quad will out perform other carbs in performance and reliability. It just has to be set up for its specific application.
LTZ Cheyenne C20
Offline boulky12
« Reply #13 on: September 16, 2016, 08:42:55 am »
Yes choke plate should be fully open when you start the engine cold and should slowly close as the engine warms up.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Offline dar06003
« Reply #14 on: September 16, 2016, 09:36:10 am »
So why does my engine idle at like 4000 rpm when I start it? I've done a lot of work on the engine over the past few weeks, I deleted the EGR and  AIR pump, added headers new exhaust system, new carb, I'm not sure where I screwed up putting it back together.
