Author Topic: I need some help....  (Read 5433 times)
Offline bike4life454
« on: September 29, 2016, 07:22:36 pm »
I have been trying to find a replacement for the steering shaft coupling(I'm not sure that's what it is so I circled the part in the picture) but I cent find it anywhere.. If anyone knows where to get it other than a junk yard I would really appreciate it.
http://cloud.tapatalk.com/s/57edb0461c3dd/Capture%2B_2016-09-29-17-10-42.png?
Sent from my VS985 4G using Tapatalk
Re: I need some help....
« Reply #1 on: September 29, 2016, 07:57:25 pm »
called a rag joint. they sell them at your local parts store for not too much. theres two sizes, should be the smaller size
« Reply #2 on: September 29, 2016, 08:57:33 pm »
I was under the impression the rag joint was the component closer to the steering box..
« Reply #3 on: September 29, 2016, 09:04:25 pm »
sorry cant see the picture due to a firewall. but yes the rag joint connects the steering intermediate shaft with the steering box
« Reply #4 on: September 29, 2016, 09:52:53 pm »
That's what I thought. But it's the piece closer to the steering column, mine has a shoot ton of play.
Offline SinisterC10
« Reply #5 on: October 04, 2016, 11:10:57 pm »
That part is called an intermediate shaft steering u-joint.....or steering U-joint for short.
If you were to remove that metal cover and boot you would see a u-joint in there similar to a driveline ujoint....just smaller.
If you can't find one at your local parts store or through one of the resto sites then go to  http://www.borgeson.com/xcart/home.php?cat=34
Borgeson makes top of the line steering parts. If you have to end up buying the entire intermediate shaft assembled then get it from Borgeson instead of a factory replacement or repop part. They are close to the same price.
I would never put a used joint or intermediate shaft assembly from a junkyard back on. Always buy these parts new.
« Last Edit: October 05, 2016, 12:03:20 am by SinisterC10 »
