Author Topic: inner fender removal/heater core  (Read 4176 times)
Offline NCali
« on: October 09, 2016, 01:55:23 pm »
2 wd 1/2 ton w air
I am replacing the heater core and I read the post in the tech section.
I removed the bolts on the inner fender to move it out of the way and it dont move
it looks like I am going to have to un bolt the fender because the inner fits inside of the fender
Also I cant even see the bolts I need to remove. Are they inside the ac evap housing?
Black Labs Matter
Offline NCali
Re: inner fender removal/heater core
« Reply #1 on: October 09, 2016, 03:18:54 pm »
Got it: so in the tech section :heater core removal: under the with ac instructions:
you might ad  removing the inner fender well because you cant see the bolts going through the fire wall unless you do
Black Labs Matter
« Reply #2 on: October 09, 2016, 04:39:47 pm »
Which thread were you looking at? Yes you need to remove the inner fender in order to access the bolts on the firewall.
Offline NCali
« Reply #3 on: October 09, 2016, 06:46:51 pm »
once the inner fender is out there is plenty of room to do all kinds of stuff
Black Labs Matter
Offline redhot1.4
« Reply #4 on: October 13, 2016, 03:20:14 pm »
Negative on removing the inner fender well. A swivel some tape to keep from rolling to much and 4 extensions you can get that nut off with out dropping the fender well or drilling holes
Sent from my SAMSUNG-SM-G870A using Tapatalk
