Author Topic: infamous frame crack 87 v10 repair?  (Read 7077 times)
Offline gmcdwight
« on: August 27, 2006, 02:23:00 pm »
I repaired this problem by welding 1/8 inch steel on the top and bottom of the frame rails.I also sandwhiched 1/8 inch steel on both sides of the frame rails.Now i what to do a frame up restoration to the truck.What should i do? should i buy a new frame? or will that frame be okay? Let me Know fellow ck pickup owners.>:
Offline 123 pugsy
Re: infamous frame crack 87 v10 repair?
« Reply #1 on: August 27, 2006, 01:48:00 pm »
Sounds like you did a good job.Your frame should be fine.
Check it closely when you do your frame off.
Pugsy
76 C10 LWB
TPI 350
Offline Pushrod
« Reply #2 on: August 27, 2006, 03:41:00 pm »
out of curiosity, where is this infamous crack usually at?
Junkie 77 Stepside AKA "The Sanford Machine"
81 Malibu 350 and a 4 speed
« Reply #3 on: August 27, 2006, 10:14:00 pm »
I believe he is referring to the frame cracking behind the steering gearbox. Many especially the 73-80 frames would crack and the gear box would actually pull right off the frame if it got bad enough.
Offline gmcdwight
« Reply #4 on: August 28, 2006, 12:38:00 pm »
I am refering to the crack that appears before the drivers shock right by the crossmember under the bed but before the rear axle, i will take pictures and post them for you guys to check out.
Offline 123 pugsy
« Reply #5 on: August 28, 2006, 02:10:00 pm »
Haven't heard of that one.I thought you were talking about the front at the steering box also.
Pugsy
76 C10 LWB
TPI 350
« Reply #6 on: August 29, 2006, 05:53:00 pm »
Yeah that's not really an infamous frame crack...I've never seen one crack there.
