Author Topic: floor pan that i can't find  (Read 5504 times)
Offline gmcdwight
« on: August 27, 2006, 02:09:00 pm »
I need a patch panel for the floor pan in back of the seat that meets the rear cab wall and runs from cab corner to cab corner. Someone please let me know where i can find this panel.Thanks
Re: floor pan that i can't find
« Reply #1 on: August 27, 2006, 10:16:00 pm »
I don't think I've ever seen a repair panel for the rear cab section. That isn't usually where they rot. Not sure where you'd get one without just fabricating something.
Offline roundedline
« Reply #2 on: August 27, 2006, 11:31:00 pm »
That piece is not availible, you are going to have to make it.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline gmcdwight
« Reply #3 on: August 28, 2006, 12:41:00 pm »
I kind of figured i had to fabricate that piece.I believe that piece got screwed up because of bad body mounts, which caused the sheet metal to crack instead of rotting. Thanks guys
« Reply #4 on: August 31, 2006, 10:47:00 pm »
If its crakck not rusty just egt it flat and weld the cracks up, then lay a panel over the repair or strength.
