Author Topic: !982 Chevy C-10 Lowering questions  (Read 10481 times)
Offline bnhall
« on: October 31, 2016, 02:58:24 pm »
Ok guys, I need some advice.  I have a 1982 Chevy Shortwide C10 with a 350.  I have purchased the DJM upper and Lower control arms and the 6" flip Kit from bell tech.  I also purchased the CPP big brake kit installing all new 13" disk brakes all around.  Ok here is the question,  The CCP BBK came with new spindles what I didn't know is those spindles have a 2 1/2" drop in them.  Can I still use the upper and lower control arms from DJM  Because they have the deep spring pocket built in giving them a 3" drop.  I am wanting a 4 to 5" drop in the front and a 6" drop in the back.  I am also wanting to run 20x10,  285x50x20 in the front and back.  Will i have any road clearance issues if i go with a rim and tire this tall.  also will i have any problems alining the front end?
Thanks
Offline bnhall
Re: !982 Chevy C-10 Lowering questions
« Reply #1 on: October 31, 2016, 08:21:37 pm »
Can I run DJM lowers with a 2.5" drop spindle?
Offline SkinnyG
  • Reducing resale value since 8-track days
« Reply #2 on: October 31, 2016, 10:35:47 pm »
It is not good practice to run a dropped arm and a dropped spindle at the same time.
The bottom of the factory arms get pretty close to the ground with spindles.  Mine are a bit over 3" off the ground at the lowest.  Dropped control arms lower the spring pocket even further - this could be dangerous on the street; don't do it.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
Offline MrFiveOh
  • The Local Po-Po
« Reply #3 on: November 01, 2016, 10:46:44 am »
Thanks
You wont like 285 all the way around. Its going to pull hard at every notch in the road. a 50 series tires is most likely going to rub if you have tire wells still.  If you want 4 in the front go with either the spindle and a 3/4 ton spring with one coil cut or the control arms.
1974 C-10 AKA "Smurf"
Offline bnhall
« Reply #4 on: November 01, 2016, 11:21:31 am »
Thanks for all the advice. Returning the lowers, next question can you mix lower and upper control arm manufacturers?  Like DJM uppers and CPP LOWERS?
Offline MrFiveOh
  • The Local Po-Po
« Reply #5 on: November 01, 2016, 11:27:04 am »
I wouldn't suggest it. Its like using lowering springs from two different companies, too many variables, fitment issue ect. What do you plan on doing now?
Offline bnhall
« Reply #6 on: November 01, 2016, 11:32:22 am »
I have two options keep the DJM upper tubular control arm and buy a stock lower control arm, send both upper and lower control arms back and go with a different manufacturer, Like CPP. Only thing is they are way more expensive!$$$$
Offline bnhall
« Reply #7 on: November 01, 2016, 11:33:30 am »
Any suggestions?
Offline MrFiveOh
  • The Local Po-Po
« Reply #8 on: November 01, 2016, 11:47:14 am »
Honestly, I would go with CPP modular spindle with a 3/4 ton factory spring, cut one coil. it will give you a 4-4.5 inch drop in front. Less work, and the ride is really good. Dont stick with factory 1/2 ton springs they are too spongey and will not give a good ride.
