Author Topic: Wiper Electrical Question.  (Read 4281 times)
Offline Militiaman55
  • 74 K10 Cheyenne
« on: October 31, 2016, 05:14:37 pm »
1974 K10 Cheyenne
Simple question, hopefully a simple solution!  What would cause the windshield washer pump to operate no matter the wiper switch position?  High, low, off/park all work as they should, except washer fluid is flying at all times.  If I push the switch to activate the washer pump nothing changes, meaning washer fluid still pumps out. It only stops if I turn the wipers off.
Rob
Re: Wiper Electrical Question.
« Reply #1 on: October 31, 2016, 05:35:55 pm »
Most likely need to replace the motor. Check all of your connections and the ground.
« Reply #2 on: October 31, 2016, 06:39:59 pm »
There is a ratchet wheel and dog that are probably worn out or broken.  Unfortunately the service parts are no longer available, so to maintain the OEM design the wiper motor and washer have to be serviced as a complete assembly.  See the 1974 Service Manual for the diagnostic procedure.  Some of the Forum members have converted to a Trico replacement pump with success.
  • 74 K10 Cheyenne
« Reply #3 on: October 31, 2016, 07:02:33 pm »
Thank you gentleman.
I will go through what I can and hope for the best, replacing the complete assembly if necessary.
Kind regards,
Rob
  • 74 K10 Cheyenne
« Reply #4 on: October 31, 2016, 07:08:54 pm »
Well, looking at the Trico replacement pump it appears to operate with the OEM switch.  Given that and the price, I'm going to try it out.
Thanks for the links bd!!
Rob
