Author Topic: Bent wheels ?  (Read 4303 times)
Offline jbrow1
Bent wheels ?
« on: November 06, 2016, 04:38:25 pm »
1980 k10 stock wheels 31x10.50x15 tires
If I've had the same set of wheels balanced twice in the last month, second time was for a set of new tires, plus an alignment that time.  If my wheels were bent I'm correct in thinking one of the shops would have let me know there was an issue, correct?
I'm just trying to chase down an intermittent shake/bobble to my truck, and I was hoping new tires would do the trick.
Offline FlatBlack77
Re: Bent wheels ?
« Reply #1 on: November 06, 2016, 05:40:16 pm »
i would hope the shop would say something about a bent wheel
is the shake in the front or the back?
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Bent wheels ?
« Reply #2 on: November 06, 2016, 06:36:44 pm »
A tire shop will/should let you know if there is a visible deformity or the rim is bent, what they may not be able to tell you is if it is out of round, or if it is bent it is not easily identified by the eye.
 1986 Chevy K30(under repair)
Offline jbrow1
Re: Bent wheels ?
« Reply #3 on: November 06, 2016, 08:16:58 pm »
Kind of what I figured.  I took my wifes car for an alignment once, and they said they couldn't do it b/c the wheels were bent.  Figured I'd get the same now with my truck if that were the case.
I got these wheels from a salvage yard probably 12-13 years ago, and we put them on a tire machine and spun them by hand with a straight edge to verify they were straight, and round.  Never really hit anything since, so figured they must still be ok.  Simply second guessing things.
