Author Topic: 1986 C10 transmission pan  (Read 4766 times)
Offline Jordan86
« on: November 10, 2016, 02:16:03 pm »
Do you have to remove the cross member to remove the transmission pan?
Re: 1986 C10 transmission pan
« Reply #1 on: November 10, 2016, 03:00:47 pm »
Normally no but if the transmission mount is original and is squashed you may need to jack up the rear a bit to get the pan out.
« Reply #2 on: November 10, 2016, 03:30:44 pm »
its been years but i want to say on my 86 it had a th350 (not original) but it made it easier to unbolt the trans mount and slide it back to get to the back bolts on the pan
« Reply #3 on: November 10, 2016, 04:08:02 pm »
Elaborating on what has already been stated, the leading flange of the cross member shrouds the rear pan bolts and pan flange on a 700R4 making for difficult access.  A flex-socket will engage the bolts with a little bit of finagling.  But, to remove the pan you may need to unbolt the rear mount and raise the transmission or slide the cross member slightly rearward.
Offline gunrac
« Reply #4 on: November 11, 2016, 09:40:53 am »
+1....just finished puttin in new filter. Before messing with pan bolts, unbolt mount off of cross member, raise tranny an back up cross member, also found that unbolting tranny mount off of tranny made cleaning, a lot easier an nicer clean up.
Never Apologize..........as it shows signs of weakness
Offline Jordan86
« Reply #5 on: November 11, 2016, 04:00:49 pm »
Thank You!!
