Author Topic: Old Insulation under Carpet. Needed?  (Read 8623 times)
Offline Spool
« on: December 02, 2016, 09:16:54 pm »
Hey Guys.
73' C20 Chevy.
Gutting the interior to do some mod's and under the carpet there is some terrible material which is partly damp and has
been rusting my floor.
Is it insulation? Is it necessary to replace and if so, costly?
At this point, I'm thinking I'm going to just drop the carpet back in without it. Any pointers or concerns?
Thanks guys.
-Thomas.
Re: Old Insulation under Carpet. Needed?
« Reply #1 on: December 03, 2016, 10:20:19 am »
Google carpet jute
The rugs here can be purchased with jute I believe but ask Chris to confirm.
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=CTGY&Store_Code=7&Category_Code=FLRNG
Offline Thundergrunt
« Reply #2 on: December 03, 2016, 11:30:26 am »
The dampness may be from a heater core leak. May want to check it out before installing new carpet.
Offline Spool
« Reply #3 on: December 03, 2016, 01:32:52 pm »
No heater or AC, or leaks.
But it's certainly damp, the rust damage looks old, so maybe someone before me is guilty.
I'll keep the old and replace it in January hopefully.
Is there a product that helps with rust? Or is it pretty much just eating away at the metal?
-Thomas.
Online Captkaos
« Reply #4 on: December 05, 2016, 11:02:01 pm »
Chassis Saver, POR15 are what I have used once you clean all the rust off.  You can also used a converter on it.
Our carpet kits listed above come with Jute attached to it.  If it is damp you have a leak.  with the carpet out pour water in the cowl.
Offline Spool
« Reply #5 on: December 06, 2016, 11:34:13 am »
Thanks Captkaos,
But any ideas as to what would be leaking? I don't have an AC... I can't think of anything other than weather from underneath; like nighttime moisture or dew?
-Thomas.
Offline Rattler12
  • Old Geezer
« Reply #6 on: December 06, 2016, 03:48:23 pm »
In a vehicle that old probably leaking around the windshield... in several places more than likely. When restoring my 83, when I took the windshield out there were several holes rusted though along the bottom of the windshield frame which I had to patch. When I took a wire brush to it found several more that the paint was holding together......probably not what you wanted to hear.
83 C-10 shorty 454, 5spd, 3:73 posi
« Reply #7 on: December 06, 2016, 05:38:14 pm »
grab a bright light and a friend with a garden hose. Lay on the floor and watch
Online Captkaos
« Reply #8 on: December 06, 2016, 10:01:26 pm »
Pour water down the cowl with a hose.  If you don't want a mess, take everything off the floor.
squarebody.biz
Offline Spool
« Reply #9 on: February 15, 2017, 03:34:02 pm »
Heater core. My heater core was leaking. Fixed now.
Thanks guys.
Offline Dr_Snooz
« Reply #10 on: February 15, 2017, 11:29:46 pm »
The insulation helps greatly to minimize road noise. Definitely something you want to keep.
Online Captkaos
« Reply #11 on: February 16, 2017, 06:49:45 am »
BTW we also sell Silent Coat weatherstripping that is easy to use and reduces road noise.
