Author Topic: whinner drive train  (Read 6849 times)
Offline gunrac
whinner drive train
« on: December 06, 2016, 07:02:26 pm »
94 chevy extend a cab 1/2 ton......whines bad anymore from rearend......can't figure out.....can the carrier berring do this w/o a clunk?
Never Apologize..........as it shows signs of weakness
Re: whinner drive train
« Reply #1 on: December 06, 2016, 08:36:02 pm »
Quote
what? lol
« Reply #2 on: December 06, 2016, 09:57:33 pm »
Need more info
squarebody.biz
Offline gunrac
« Reply #3 on: December 07, 2016, 09:02:42 am »
94 heavy 1/2 ton . 2500 series. As a daily driver, seems like the rear end makes a whining noise. Not sure how to check for the source. Full of gear oil.
 It is a 2 piece drive shaft w/carrier bearing. I've had carrier bearings go bad, making all kinds of noise. Not sure if this one is in the beginning stage of going out or not.
 I don't believe its in the trans. as the noise doesn't seem to change while shifting. I have put it in neutral, let coast to a stop, w/no change in noise, just slowly gets quieter till stop, no noise until take off.
« Reply #4 on: December 08, 2016, 07:46:27 pm »
You need to identify the source location start reaearching.  If you think it is the rear it could be worn gears, bearings...
squarebody.biz
« Reply #5 on: December 08, 2016, 10:29:31 pm »
ive had a carrier bearing squeal at any speed above 20 no matter what speed or if it was in neural
Offline gunrac
« Reply #6 on: December 10, 2016, 02:56:53 pm »
after checking carrier bearing, the rubber was dry rotted pretty bad. dropped the shaft, problem now is, it looks like someone has pried against the collar. this as i understand should unscrew to let the 2 shafts separate. if it is threaded, it must be stripped out. will not unscrew out....just turns. not sure what to do about it now.
« Reply #7 on: December 10, 2016, 03:10:38 pm »
when i did mine i dont remember having to unscrew a collar, i think i had to work on it but i want to say they kind of stick together and you have to pull them apart. want to say i took it completely apart from the trans, the bearing bolts and the rear. put it up on the shop table and started to work on it
Offline gunrac
« Reply #8 on: December 10, 2016, 09:44:00 pm »
had a ford that unscrewed.......assumed chevy did to.... took it to napa....wouldn't separate for them either......locked in vice didn't help.......moves a few inch's.....just won't let loose
Offline gunrac
« Reply #9 on: December 14, 2016, 08:35:58 am »
Follow up.
I did finally get it apart......it was pressed on. Couldn't reuse it. Put a boot on instead. The carrier was so tight it was all you could do to turn it by hand.
I have been told before that the W/T trucks were made up by over stock surplus parts chevy had on hand. The book said the  carrier bearing could have been 1 of 2 bearings, neither would work. After doing all the measurements, it turns out it was the same bearing that was used in a C-60. Replaced it.  Eliminated the noise.
All worked out for the best.
