Author Topic: Caulk for under dash area  (Read 4307 times)
Offline 76Texan
  • 76 Scottsdale Owner
« on: December 26, 2016, 03:29:14 pm »
Hey all...
The worst rust in the cab was behind the AC, the rest was surface rust here and there. Going to go with POR15. Of course will scrape and clean all of the loose rust off. Was going to use some Lexel Caulk in various areas of the cab. However the seem running under the AC area there where the rust is and all along that will the caulk need to be more heat resistant?
Thanks much in advance!
1976 Scottsdale K10
Re: Caulk for under dash area
« Reply #1 on: December 26, 2016, 06:41:43 pm »
Seam Sealer but remove the rust first, prime and paint.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #2 on: December 26, 2016, 07:56:50 pm »
Not familiar with lexel , but automotive seam sealer is supposed to be resistant to certain chemicals and heat.
 1986 Chevy K30(under repair)
Offline 76Texan
« Reply #3 on: December 27, 2016, 04:42:10 pm »
Thnaks guys!
Noticed someone saying it was flexible more than other types. Just ordered some of the auto seam sealer, THX!
1976 Scottsdale K10
Offline blazer74
« Reply #4 on: December 27, 2016, 07:16:39 pm »
You can buy it at Autozone.
