Author Topic: Door jamb dome light switch punched through door  (Read 6665 times)
Offline chetma
« on: December 27, 2016, 09:29:40 am »
My door jamb dome light switch has punched through the door and the dome light no longer comes on due to the switch always getting stuck. Before I go and do something stupid has anyone else had success in fixing this without welding. I was almost thinking about drilling a hole and then kinda counter sinking a screw into there to have the plunger hit something to activate the light. Good idea or bad. Thanks
Offline gunrac
Re: Door jamb dome light switch punched through door
« Reply #1 on: December 27, 2016, 10:03:49 am »
my ol' 85' has been shot for yrs.     mine does still work off the lite switch tho.....matter of personal preference I guess.....maybe JB weld a small piece of thin sheet metal over the hole.
Never Apologize..........as it shows signs of weakness
Offline chetma
« Reply #2 on: December 27, 2016, 10:22:30 am »
I have tried the jb weld route and it lasts about 3 door slams. And then cracks off. Thanks though
« Reply #3 on: December 27, 2016, 11:21:06 am »
rivet a small panel to the door
Offline DanMcG
« Reply #4 on: December 28, 2016, 03:54:23 am »
I'd do the same but with an elevator bolt.
« Reply #5 on: December 28, 2016, 01:39:16 pm »
Replace the switch and glue on a blank with adhesive sealant. Let it dry overnight.
Offline Jerr-conn
  • Retired tool maker
« Reply #6 on: February 03, 2017, 07:20:22 pm »
Chetma , just saw your post from dec, 2016. I think you have the best idea to drill and c' sink
For a  flat head bolt to fix your door switch. Anything else would look Cobbled.
Jerry
Offline 75gmck25
« Reply #7 on: March 10, 2017, 11:04:14 am »
When I bought some add-on courtesy lights they came with new door switches.  However, the diameter for the threaded portion was larger than the original ones in the truck.
I ended up cleaning and re-using the original switches.  However, I could have drilled and tapped the door fitting for a larger diameter switch, which might fix your problem.
Bruce
« Last Edit: March 10, 2017, 11:29:03 am by bd »
Offline kcwis
« Reply #8 on: March 18, 2017, 02:59:04 pm »
Any idea where I can find the switches with the larger diameter?  Mine are stripped out.
« Last Edit: March 18, 2017, 03:48:28 pm by bd »
